SHOUTcast Radio - Popular 128kbps Music Streams
Xmantium
Post Fri Jan 13, 2012 3:37 am
I cant find any decent sites anywhere where it lists the popular SHOUTcast URL
So here is my tested popular 128kbps streams
Remember to select "Live Stream" and select Audio for it to work, i'll add thumbnails later ;)
Will be adding more soon, keep me posted if you like of your shoutcast links :D
Pop
idobi Radio - http://50.117.115.210 or http://eg2.idobi.com or http://hobbes.idobi.com
.977 The Hitz Channel - http://205.188.215.230:8002
.977 The 80s Channel - http://205.188.215.229:8004
181.FM - POWER 181 - http://205.188.215.228:8002
1POWER - http://205.188.215.229:8006
108.FM - THE HITLIST - http://205.188.215.229:8042
HIT104 - http://thegrid.worldblu.com
R&B/Urban
HOT 108 JAMZ - http://205.188.215.229:8040
DEFJAY.COM - http://he-srv1.defjay.com or http://listen.defjay.com
181.FM (R&B) - http://relay1.181.fm:8022
Alternative/Rock
181.FM (Alternative) - http://205.188.215.229:8002
181.FM (90s Alternative) - http://67.202.67.18:8122
ChroniX Aggression - http://205.188.215.225:8010
ChroniX Metal - http://205.188.215.225:8022
#MUSIK.ROCK - http://87.230.101.23:10000
Post Fri Jan 13, 2012 5:16 am
Re: SHOUTcast Radio - Popular 128kbps Music Streams
OK, It would be great if you would make RSS folders for each of these genres.
They are a lot easier to maintain than adding each feed to the console.
Getting Shoutcast urls is easy.
1) open http://www.shoutcast.com
2) view the page source
3) search for pls?id= and you will find all the station names and urls for the top stations as below.
4) download those playlists and use the url in the File1= entry
5) click on the genres to the right and repeat to get the top genre stations.
  <a class="playbutton playimage" id="172748" name="MusicRadio@Auto By Pj  Neoone" href="http://yp.shoutcast.com/sbin/tunein-station.pls?id=172748"></a>
Xmantium
Post Fri Jan 13, 2012 2:09 pm
Ah! I'll check for that. This way above the user can put in their favourite stream rather than going through a big list.
Is there a preloaded rrs feeds for shoutcast music genres on a site?
Post Fri Jan 13, 2012 2:16 pm
Xmantium wrote: This way above the user can put in their favourite stream rather than going through a big list.?
Yes by building their own rss of those live feeds per the wiki
No, that's why I suggested you build the stock rss's for the most popular and some of the genres per the wiki
Post Fri Jan 13, 2012 2:35 pm
Thare is a TuneIn plugin in dev phase, but you can give it a try: viewtopic.php?f=21&t=4454#p31963
roaming
Post Mon Jan 16, 2012 11:53 am
Pretty old this post but I am using it for my problem: live stream only works for me for a while (some seconds) and then switches off !! And this is happening with any stream URL. Some help would be much appreciated... :)
Roaming, free the speech...
http://roaming.op351.net/
Porto * PORTUGAL
netRADIO | photoBLOG
Post Mon Jan 16, 2012 2:00 pm
I've posted a Shoutcast plugin in the Available plug=ins.
First Version does the top 10 feeds as on www.shoutcast.com/
Post Mon Jan 16, 2012 2:15 pm
roaming wrote:Pretty old this post but I am using it for my problem: live stream only works for me for a while (some seconds) and then switches off !! And this is happening with any stream URL. Some help would be much appreciated... :)
Why would you post this under shoutcast? Ifyou post under General Discussion, with some examples of the streams that do not work and how you set them up, and the ffmpeg -i output and the Serviio log, we can diagnose it for you, just like an EE figures out why the lights don't turn on!
blase
Post Sat Nov 10, 2012 11:08 am
Hi all
I am creating my own with my RSS favorias stations and not get it to work.
I put the code I tried to tell me where is the fault
<item>
      <title>HOT 108 JAMZ</title>
      <link>http://link1</link>
      <media:stream url="http://yp.shoutcast.com/sbin/tunein-station.pls?id=32999"  type="audio" />
      <media:thumbnail url="https://sites.google.com/site/serviiorss/redlight2.png" />
   </item>
<item>
      <title>TurntableTendencies.com</title>
      <media:stream url="http://99.198.101.250:80" type="audio" />
   </item>
in either case I do not see any station
Thanks and sorry for my English
harrybro
Post Wed Nov 21, 2012 12:32 pm
thanks for this shortcut,,,
harrybro
PC Bigboy
Post Fri Mar 07, 2014 12:10 pm
jhb50 wrote:OK, It would be great if you would make RSS folders for each of these genres.
There's an EVEN EASIER way to do it.
1) Open Winamp (RECOMMENDED)
2) Go to the SHOUTcast website
3) Find a station you want & click on the link (Make sure your SHOUTcast.com settings are set to USE EXTERNAL PLAYER as the link WILL activate Winamp !!)
4) IN WINAMP - Highlight & select VIEW FILE INFO (Or sompley hit ALT+F3 on your keyboard)
5) Copy the provided URL to clipboard & paste into Serviio
DISCLAIMER - IN THEORY this is supposed to work though I have yet to get it to do so with Serviio & my Playstation 3. As such, I could be doing something wrong.....
Hope this helps :)
Cheers :)
Pat Cook
Englewood, CO
Paul C
Post Sat Mar 03, 2018 11:57 pm
Xmantium wrote: So here is my tested popular 128kbps streams
Pop
idobi Radio - http://50.117.115.210 - VALID
R&B/Urban
181.FM (R&B) - http://relay1.181.fm:8022 - VALID
Alternative/Rock
As at 2018 only two of the above Internet Radio station URLs from the 2011 list are valid according to Serviio (namely idobi Radio - http://50.117.115.210 and 181.FM (R&B) - http://relay1.181.fm:8022).
Hot 108 JAMZ is available on a different URL in our existing list.
Internet Radio stations disappear or change their streaming URL due to servers or technology e.g MP3 to aac+.
I have added the working ones to a future list see viewtopic.php?f=42&t=24378#p116776
Return to Audio streams
