BDP-S370 - Images problem
blm
Post Sun Jan 23, 2011 12:47 pm
Hi!
My BR Player doesn't see images. Folders list are actual but all are empty.
patters
Post Tue Jan 25, 2011 12:25 pm
Re: BDP-S370 - Images problem
Did you give it time to build your library? I can confirm it works for me, though I had to wait until all the rest of my media was catalogued.
blm
Post Sat Feb 05, 2011 10:25 pm
To test it I have added two movies and some image files (bmp, jpg, png, jpeg). Movies are visible, images not. Any idea?
patters
Post Sat Feb 05, 2011 10:29 pm
Make sure you are browsing images from the image section of the Sony XMB (press Home then left several times). The Serviio audio, image and video folders will all show up in each category due to how DLNA servers work - it's just the Sony that insists on having a menu for each category.
blm
Post Sat Feb 05, 2011 10:37 pm
My mistake.. You have right.. I'm browsing wrong folder.
Thanks for help!
