.strm files not shown after upgrading to serviio 1.4
hoobastalib
Post Sat Mar 08, 2014 2:47 pm
Hi everyone
My sony bravia tv (2011) in version 1.3 was able to view .strm files that I have shared from my pc. After upgrading to serviio 1.4, the .strm files are not shown in my sony tv anymore.
It just shows a "There are no items to display" message
Anyone having the same problem or have any solution for this?
Very much appreciated!
Post Mon Mar 10, 2014 8:31 am
Re: .strm files not shown after upgrading to serviio 1.4
Could you provide information about such strm file format? see signature links.
hoobastalib
Post Mon Mar 10, 2014 2:25 pm
Thanks for the reply! this is what I saw in the logs
[FeedUpdaterThread] Failed to retrieve online item information for http://localhost:8902/tv.asf. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:454)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:97)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:135)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
and the contents of my .strm are just the following:
http://127.0.0.1:8902/tv.asf
I used vlc player on my ipad to get the stream from my pc and it works fine.
What baffles me is that this used to work for me on my sony tv but this update seemed to have done something :(
Post Mon Mar 10, 2014 3:45 pm
Could you provide the result of this command line,
ffmpeg.exe -i "http://127.0.0.1:8902/tv.asf"
Open a windows terminal and use the ffmpeg.exe from the ../serviio/lib/ffmpeg.exe
I will try to find what are changes between 1.3 and 1.4 version...
Iveky
Post Mon Mar 10, 2014 3:56 pm
it is some AcePlayer on PC?
hoobastalib
Post Sun Mar 16, 2014 1:32 pm
Here it is Illico
E:\Program Files\Serviio\lib> ffmpeg.exe -i "http://127.0.0.1:8902/tv.asf"
[h264 @ 03ABFCA0] non-existing PPS referenced
[h264 @ 03ABFCA0] non-existing PPS 0 referenced
[h264 @ 03ABFCA0] decode_slice_header error
[h264 @ 03ABFCA0] no frame!
[mpegts @ 01CAECA0] max_analyze_duration 5000000 reached at 5016000 microseconds
Input #0, mpegts, from 'http://127.0.0.1:8902/tv.asf':
  Duration: N/A, start: 44289.297767, bitrate: 128 kb/s
  Program 1
    Stream #0:0[0x44](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo
, s16p, 128 kb/s
    Stream #0:1[0x45]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuvj420p, 12
80x720 [SAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
Illico wrote:Could you provide the result of this command line,
hoobastalib
Post Sun Mar 16, 2014 1:33 pm
Iveky wrote:it is some AcePlayer on PC?
yeapz.
hoobastalib
Post Wed Apr 09, 2014 11:13 pm
anyone? :(
