After upgrading to 1.4.1 choppy play and freezing
jadrake75
Post Thu Mar 13, 2014 5:01 pm
I upgraded to 1.4.1 last night on my Fedora 20 server last night and I have been having nothing but problems since with video playback.
Turning on DEBUG in the logs did not provide me with any useful information.
I did notice in the logs a message:
2014-03-13 10:25:02,722 WARN  [PortMapper] Could not find a router on the network. Autodiscovery (UPnP/NAP PMP) might be disabled or the router is not currently supported.
That I see ~ every 10 minutes. I don't have the logs from 1.4 to know if this was present there. It also seems like the hangups are not related to this activity (they have occurred in between the 10 min window). I was having a bunch of errors related to some m4v files not being able to detect media type, but I removed these and restarted serviio and I am still seeing problems (this was an experimentation anyhow)
All of my movies are my MKV rips from MakeMKV (either blu-ray or dvd). For blu-ray's I have down-converted the video stream via ffmpeg to a lower bit rate ~ 15Mbps. (they are about 12.0-15gb down from 24+). All video has been playing fine for over a year until this upgrade. I have a myriad of devices I play them on but my main device (that I care about) are my two WDTV Live boxes. These are connected to a GB/s network to the server (even though they only have 100Mbps network adapters). All routers, network devices, and WD TV Live boxes have been cold-booted (power jack removed, 10+ second wait time and hard start) The last WDTV Live update was well over a month ago and I have seen at least 100+ movies since then (my daughter was home for a while and we watched a lot of Disney flicks!) without issue. While WDTV can be finnicky, I do not believe it is the issue here, nor do I think there is issues with the network. I believe it is on the server side only.
At random times (sometimes about 20 minutes in but can be periodic) it will freeze, skip ahead or outright stop playing on my movies. As everyone knwos this is frustrating.
I have monitored the System monitor when this happens. Everything drops off. and I mean everything. CPU 0%, network 0% .... the whole thing just goes out to lunch. Then a few seconds latter everything spikes and it goes back to normal until the next random event (sometimes in minutes and sometimes seconds latter).
My Server is more than capable. E5 Xeon (8 cores) with 8GB RAM running Linux - there is other software on there but nothing that would cause this - a glassfish application server, mysql etc. - they consume RAM but not to the level that should be interefering. I am running the videos from a RAID-6 disk array (6 disks) that output whopping read speeds (so that is not a bottle neck) and the RAID is in good condition without errors.
I am running the latest version of Java JDK
Java(TM) SE Runtime Environment (build 1.7.0_51-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.51-b03, mixed mode)
I did try and compile ffmpeg as well and here is what I am using from that:
ffmpeg version 2.1.4 Copyright (c) 2000-2014 the FFmpeg developers
  built on Feb 25 2014 08:24:47 with gcc 4.8.2 (GCC) 20131212 (Red Hat 4.8.2-7)
 libavutil      52. 48.101 / 52. 48.101
  libavcodec     55. 39.101 / 55. 39.101
  libavformat    55. 19.104 / 55. 19.104
  libavdevice    55.  5.100 / 55.  5.100
  libavfilter     3. 90.100 /  3. 90.100
  libavresample   1.  1.  0 /  1.  1.  0
  libswscale      2.  5.101 /  2.  5.101
  libswresample   0. 17.104 /  0. 17.104
Also, if 1.4 available somewhere? It looks like the download link only has the latest. I would have liked to revert to 1.4 (I didn't back it up) and try that to compare.
-Jason
Post Thu Mar 13, 2014 5:15 pm
Re: After upgrading to 1.4.1 choppy play and freezing
Just change the URL to 1.4 in the download link, the file is still there. Although there was no change to the streaming / delivery mechanism in 1.4.1, apart from this: viewtopic.php?f=3&t=15959
jadrake75
Post Thu Mar 13, 2014 5:40 pm
Petr - the 1.4 linux tar.gz seems to be corrupt. I have tried snagging it on two differnet os, different browsers and even wget. I get a premature end of file reading it in both Linux and Windows. Here is the URI I am accessing:
http://download.serviio.org/releases/se ... nux.tar.gz
Post Fri Mar 14, 2014 12:42 am
Should be working now
jadrake75
Post Fri Mar 14, 2014 6:59 pm
Ok I can confirm I am NOT seeing any problems using Serviio 1.4.0 - I have watched two high bitate MKVs without so much of a hangup or a blip.
Now.... I also had a disk failure in the RAID-6 system. So before you "go further" on this, let me get the new disk sync'd on the RAID and I will bring back the 1.4.1 install online and test again.
Thanks for your help (I will report back what I find with the full RAID-6 online)
Post Fri Mar 14, 2014 8:58 pm
jadrake75
Post Sun Mar 16, 2014 5:56 am
Ok - I am pretty certain the issue I was running into was caused by my RAID-6 failure/errors
My daughter watched a boat load of crappy movies today and I watched a high bit rate blu-ray MKV without any issues.... I suspect the disk went (I did not realize I didn't have the smart daemon running) and since the system was "up" it was just gettting tripped on when bits from that disk were accessed. I am not seeing any issues now.
Reconfigured as RAID-1s (multiple disk spans) to simplify my life.
-Jason
Users browsing this forum: Google [Bot] and 58 guests
