Using Serviio with MySQL
npuser
Post Fri Mar 14, 2014 1:30 am
Re: Using Serviio with MySQL
drungrin wrote:No need to reverse engineer using the 1.4.1 version.
Ok. Will give it a go.
@DenyAll - I think we can take this out of beta (restricted) subsection to main forum for a greater visibility. Hopefully, this will inspire someone to create a web library management tools.
Npuser
Post Wed May 14, 2014 11:19 pm
Reverted back to General Discussions area of the forum.
istasi
Post Mon May 19, 2014 7:31 pm
db_schema_url=jdbc:mysql://localhost/serviio?user=istasi&password=main
Im using mysql-connector-java-5.1.28.jar
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'FETCH FIRST 1 ROW ONLY' at line 1
Any reason why the databasemanager is still returning type as derby? -.-
Current version of serviio is 1.4.1.1 but i've tried with 1.4.1.2 and 1.4.1, just cause well, it might work? -.-'
tpol
Post Tue Sep 30, 2014 3:11 pm
I followed the instruction on the first post, serviio (version 1.4.1.2) doesn't complete the startup process, it's stuck somewhere, i enabled the debug level:
2014-09-30 17:16:33,649 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2014-09-30 17:16:33,838 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2014-09-30 17:16:33,868 INFO [DatabaseManager] Using MYSQL database language
2014-09-30 17:16:43,761 DEBUG [DBSchemaUpdateExecutor] Error reading db log table, probably doesn't exist yet. Will execute the script.
2014-09-30 17:16:43,765 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2014-09-30 17:16:43,775 DEBUG [DBSchemaUpdateExecutor] Error reading db log table, probably doesn't exist yet. Will execute the script.
2014-09-30 17:16:44,071 INFO [DBSchemaUpdateExecutor] Updating DB schema
2014-09-30 17:16:44,138 DEBUG [JdbcUtils] An exception occurend when executing SQL statement
com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'DB_SCHEMA_VERSION' already exists
2014-09-30 10:06:52,487 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2014-09-30 17:18:36,892 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
The last line says "Reading all ConfigEntries", after that nothing more appears and it doesnt' complete the startup
Do u have any idea? what do i miss to correctly switch to mysql?
LonelyWolf
Post Tue Nov 11, 2014 4:26 pm
Hi, I followed the instruction on the first page and all goes well (in my test enviroment!).
Now i'm writing a browser to manage the library metadata (change wrong data or add what's not recognised).
Where can i find tables fields associations or sql queries you are using?
Looking at the tables structure (i did just a quick look for now when i was migrating data from derby to mysql) i saw that in media_item table there's a column that is the id in cover_image and for genre, but not in person->person_role (why not using a base table for that like you did for genre?)
If you can put me in the right direction i'll appreciate.
P.s.
I'm using php so the library manager could be used in linux/windows/mac and i've already tested a very little "local web server" without installation for windows users.
Previous
Return to General discussion
