After update to 1.4 /1.4.1 mp4 files not playing anymore
qanatoz
Post Sat Mar 15, 2014 7:44 pm
Hi everyone,
After update to 1.4 /1.4.1 mp4 files not playing anymore.
In error log I see flowing errors:
2014-03-15 20:16:37,075 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://data12-cdn.datalock.ru/film/967d08dba03e35767007bd7a972069cc/7f_Dracula.S01E09[MEKC.INFO][NewStudio.TV].a1.18.01.14.mp4. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:320)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:237)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:116)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:467)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:100)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:138)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:299)
   ... 2 more
2014-03-15 20:16:37,994 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://data07-cdn.datalock.ru/film/967d08dba03e35767007bd7a972069cc/7f_Dracula.S01E10[MEKC.INFO][NewStudio.TV].a1.26.01.14.mp4. It might not play.
   ... 2 more
If I trying to run ffmpeg manualy using ffmpeg.exe:
Serviio\lib>ffmpeg.exe -i "http://data07-cdn.datalock.ru/film/967d08dba03e35767007bd7a972069cc/7f_Dracula.S01E10[MEKC.INFO][NewStudio.TV].a1.26.01.14.mp4"
I'm getting next output:
[http @ 0034F140] HTTP error 404 Not Found
01E10[MEKC.INFO][NewStudio.TV].a1.26.01.14.mp4: Input/output error
But if put the same link in to VLC its works fine...
Somebody can help to solve this problem?
P.S. Serviio 1.4.1, Win 7 x64
Post Mon Mar 17, 2014 10:15 pm
Re: After update to 1.4 /1.4.1 mp4 files not playing anymore
I'm getting 404 as well... does the video still exist?
qanatoz
Post Tue Mar 18, 2014 8:24 pm
Hi @zip,
Tnx for reply.
Video still exist.
If I'm trying to load it from browser I able to download the file and see video after download.
Looks like some issue with ffmpeg.
Post Wed Mar 19, 2014 12:27 pm
Might be she square brackets in the file path that FFmpeg has problems with. Try to escape them.
qanatoz
Post Wed Mar 19, 2014 9:29 pm
Hi @zip
ffmpeg.exe -i "http://data07-cdn.datalock.ru/film/967d08dba03e35767007bd7a972069cc/7f_Dracula.S01E10%5BMEKC.INFO%5D%5BNewStudio.TV%5D.a1.26.01.14.mp4"
returns same result: [http @ 01EBF180] HTTP error 404 Not Found
I not think this related to brackets in file path. I see similar errors in log also for other files.
2014-03-19 22:01:00,051 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://data09-cdn.datalock.ru/film/967d08dba03e35767007bd7a972069cc/8f_supernatural.s09e10.webdl.720p.rus.newstudio.tv.novafilm.tv.a1.25.01.14.mp4. It might not play.
qanatoz
Post Fri Mar 21, 2014 6:39 pm
I make some test with Wireshark
This the steam from ffmpeg
GET /film/5b0f75d9ff5bf8eee16f8d77fec2adbc/7f_Supernatural.S09E16.a1.21.03.14.mp4
HTTP/1.1
User-Agent: Lavf/55.9.100
Accept: */*
Range: bytes=0-
Connection: close
Host: temp-cdn.datalock.ru
HTTP/1.1 404 Not Found
Server: nginx/1.2.7
Date: Fri, 21 Mar 2014 17:17:06 GMT
Content-Type: text/html
Content-Length: 0
Connection: close
X-Powered-By: PHP/5.3.10-1ubuntu3.4
Status: 404 Not Found
Vary: Accept-Encoding
And this one from browser:
HTTP/1.1
User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:28.0) Gecko/20100101 Firefox/28.0
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
Accept-Language: en-US,en;q=0.5
Accept-Encoding: gzip, deflate
DNT: 1
Connection: keep-alive
HTTP/1.1 200 OK
Server: nginx/1.2.7
Date: Fri, 21 Mar 2014 17:35:46 GMT
Content-Type: video/mp4
Content-Length: 120377001
Last-Modified: Fri, 21 Mar 2014 07:44:23 GMT
Accept-Ranges: bytes
Post Fri Mar 21, 2014 6:48 pm
Might be due to the user-Agent. Try to pass user-agent to the ffmpeg command.
qanatoz
Post Sat Apr 05, 2014 4:24 pm
zip wrote:Might be due to the user-Agent. Try to pass user-agent to the ffmpeg command.
The same result - getting 404.
qanatoz
Post Thu May 01, 2014 8:11 pm
Any ideas?
Post Thu May 08, 2014 12:36 pm
do you use some kind of proxy in your browser?
qanatoz
Post Sat May 31, 2014 1:30 pm
Hi @zip,
No, I not use a proxy.
