Roku Profile Needed - Now Supports DLNA
Post Sun Mar 02, 2014 3:44 am
Re: Roku Profile Needed - Now Supports DLNA
donpearson wrote:Maybe I'm missing something here as I've never looked at a serviio before, just used it.
This profile don't seem to work very well for me, I have no sound when I'm playing avi and even mkv?
I know It's prob me missed something, I have a Roku 3 and running Serviio 1.4 Pro.
I have other devices that work perfect, Sony SMP-N100, Sony PS3, Xbox 360, LG TV and so on.
Make sure you've followed these steps.
    Copy this profile into the "profiles.xml" file. this is located in the config folder where Serviio is installed. Also, make sure you paste it into the file after a </profile> tag. but before the </profiles> tag.
    Either restart the Serviio process (Windows), or just to be sure, reboot the computer.
    Manually selected the Roku Media Player profile, because by default the Chaneru profile is selected for a Roku device.
    Remember to click Save after changing your selected profile.
If you still don't get any sound, try changing the profile from ac3 to aac. That's in this line:
<Video targetContainer="mpegts" targetVCodec="h264" maxVBitrate="12000" targetACodec="ac3">
Maybe my 2XS just likes AC-3 better than AAC :lol: , but it works for both of my Roku boxes. Your other devices use different profiles, so you can't compare their functionality to the Roku.
donpearson
Post Sun Mar 02, 2014 10:57 am
Thanks for that, it's now working :)
Everything was right where I put the code in the profile.
It was the ac3 it did not like, changed to aac and we are off.
Post Sun Mar 02, 2014 3:14 pm
donpearson wrote:Thanks for that, it's now working :)
:D
giantslor
Post Sun Mar 16, 2014 8:13 am
:D
atc98092, thanks for your tip on changing ac3 to acc in the profile (I did it in profiles.xml, which already contained your Roku profile). Now I have another option for watching transcoded-on-the-fly movies on my Roku 3! Except there's a problem: When I stop movie playback on my Roku, ffmpeg still keeps transcoding like crazy on my PC and the CPU is near 100%. The only way to stop this process is to stop the Serviio service. Is there something I can add to the profile to tell ffmpeg to stop after movie playback is stopped? Sorry for the noob question. (BTW, the MyMedia server from PlayOn has this exact same problem, so the issue isn't just with Serviio.)
giantslor
Post Sun Mar 16, 2014 4:43 pm
I did some searching and discovered that the "issue" of ffmpeg not stopping is by design. I understand the reasoning behind this, but if I'm playing a video just to test out the server/client, I don't want an entire movie transcoded. It would be cool if there was some command I could add to the Roku profile to stop this behavior.
Post Sun Mar 16, 2014 9:58 pm
giantslor wrote:I did some searching and discovered that the "issue" of ffmpeg not stopping is by design. I understand the reasoning behind this, but if I'm playing a video just to test out the server/client, I don't want an entire movie transcoded. It would be cool if there was some command I could add to the Roku profile to stop this behavior.
Yeah, apparently there's no way for Serviio to kill the transcode if someone stops the video stream. Of course, this isn't a Roku issue. It applies to anything that requires transcoding. Fortunately, at least with the power I have with my server, it doesn't cause an issue with performance. And don't forget, if you start streaming a different video that also requires streaming, it does kill the transcoding of the first video. It's not like they keep piling on top of each other.
zika507
Post Thu Apr 03, 2014 4:17 am
my friend i have a roku 2 XS with Serviio! i never have a problem reading video, but always i have the same problem.. the serviio does transcode the audio! because any files that i have can play with sound.. just avi with mp3 audio!
Audio like Ac3 and ACC. i cant play.. why?
i use to enter in the serrver the roku app: "Roku media player" update!
somebody can help me? :(
Post Thu Apr 03, 2014 12:40 pm
zika507 wrote:my friend i have a roku 2 XS with Serviio! i never have a problem reading video, but always i have the same problem.. the serviio does transcode the audio! because any files that i have can play with sound.. just avi with mp3 audio!
OK, I have the 2 XS and it plays perfectly. However, I don't have any AVI videos, as mine are almost all MKV. I did have sound issues at first, and for me it was changing the sound transcoding from aac to ac3. So, first we have to ask: which profile is your Roku using? There are two options: one is the Chaneru profile that comes with Serviio, and the other is the Roku Media Player profile we've listed here. When I use the Chaneru profile, I too had audio issues with the RMP, but of course the Chaneru player works fine. I'm at work right now, so I can't look at my profile to copy the precise transcoding settings I am using. I'll try to remember to grab it this evening and post it again. I know I've tweaked it a little over time, but can't remember if I've uploaded the most recent tweak here.
You might provide us a mediaInfo listing for one of your videos that won't play, just so we can see what audio codec is in use. Might be something the profile doesn't cover. And the Roku only plays a few codecs without transcoding.
zika507
Post Thu Apr 03, 2014 4:06 pm
Well my friend, i have the Roku 2 XS, Roku media player, and serviio 1.4.1.2!! and i use windows 7 pro x64
The profile im using is Roku media player ""result play videos but not the audio"
then i use the Edited Roku profile "still same"
then i use Dlna generic profile ""Still Same"
Then i use Chaneru "Roku Crash"
then i use Winows 8RT profile "Video but not Audio" still same
i think its very good idea send the profile.xml, and the version of the serviio! i really appreacite that!
also i will post some mediainfo of some files:
 Complete name                            : D:\MOVIES\007 Operacion SkyFall 720p Latino\007 Operacion SkyFall 720p Latino.mkv
File size                                : 1.28 GiB
Duration                                 : 2h 23mn
Overall bit rate                         : 1 285 Kbps
Movie name                               : By Johual - WwW.DD-Peliculas.COM
Encoded date                             : UTC 2013-02-02 16:57:47
Writing application                      : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
Writing library                          : libebml v0.8.0 + libmatroska v0.9.0
Format profile                           : High@L3.1
Duration                                 : 2h 23mn
Bit rate                                 : 900 Kbps
Height                                   : 528 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.056
Stream size                              : 896 MiB (68%)
Title                                    : WwW.DD-Peliculas.COM
Writing library                          : x264 core 98 r1649 20cbe10
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=900 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                                 : Spanish
Duration                                 : 2h 23mn
Bit rate                                 : 384 Kbps
Stream size                              : 393 MiB (30%)
Language                                 : Spanish
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Language                                 : Spanish
 Complete name                            : D:\MOVIES\Los Pitufos 2 720p Latino\Los-Pitufos-2 720p latino.mkv
File size                                : 1 012 MiB
Duration                                 : 1h 44mn
Overall bit rate                         : 1 349 Kbps
Encoded date                             : UTC 2013-11-14 06:47:14
Duration                                 : 1h 44mn
Bit rate                                 : 900 Kbps
Height                                   : 688 pixels
Display aspect ratio                     : 1.85:1
Bits/(Pixel*Frame)                       : 0.043
Stream size                              : 656 MiB (65%)
Encoding settings                        : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=900 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Language                                 : Spanish
Duration                                 : 1h 44mn
Bit rate                                 : 448 Kbps
Stream size                              : 336 MiB (33%)
Language                                 : Spanish
Text
Format                                   : UTF-8
Language                                 : Spanish
 Complete name                            : D:\MOVIES\Esto es la Guerra DUAL 2012 720p\Esto es la Guerra (2012) 720p BRRip 700MB Dual Audio.mkv
File size                                : 723 MiB
Duration                                 : 1h 44mn
Overall bit rate                         : 971 Kbps
Encoded date                             : UTC 2012-05-24 07:54:39
Writing application                      : mkvmerge v5.3.0 ('I could have danced') built on Feb  9 2012 10:38:07
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format profile                           : High@L4.0
Format settings, ReFrames                : 8 frames
Muxing mode                              : Header stripping
Duration                                 : 1h 44mn
Nominal bit rate                         : 902 Kbps
Height                                   : 536 pixels
Bits/(Pixel*Frame)                       : 0.055
Title                                    : ==== 300mbunited.me | rpnet.biz ====
Writing library                          : x264 core 120 r2120 0c7dab9
Encoding settings                        : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=902 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio #1
Format profile                           : HE-AAC / LC
Codec ID                                 : A_AAC
Duration                                 : 1h 44mn
Sampling rate                            : 48.0 KHz / 24.0 KHz
Audio #2
Codec ID                                 : A_AAC
Duration                                 : 1h 44mn
Delay relative to video                  : 31ms
Title                                    : Descarga en moviescq.com Películas y Series con la mayor calidad al menor tamaño
Language                                 : Spanish
i already attach movies with acc and ac3 audio, i cant get any sound of those files!
i really appreciate your support my friend
Post Thu Apr 03, 2014 11:49 pm
OK, here's my configuration. Roku 2 XS, firmware 5.4 build 3333. Roku Media PLayer version 4.1.0002. Serviio 1.4.1.2.
Here's the Roku profile I'm using. I believe Zip included it in the latest Serviio build, because I didn't have to add it back in after updating my server:
<Profile id="RokuMPApp" name="Roku Media Player" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <User-Agent>.*ROKU.*</User-Agent>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">MPEG4_P2_TS_ASP_MPEG2_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="MPEG_TS_SD_EU,MPEG_TS_SD_NA,MPEG_TS_SD_KO">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
            <!-- <Video targetContainer="applehttp" targetVCodec="h264" targetACodec="aac"> -->
            <Matches container="asf" />
            <Matches container="mpegvideo" />
            <Matches container="mpeg" />
            <Matches container="mpegts" />
            <Matches container="avi" />
            <Matches container="flv" />
            <Matches container="wtv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Matches container="rtp" />
            <Matches container="rtsp" />
            <Matches container="rm" />
         <Video targetContainer="mpegts" targetACodec="aac" aBitrate="320">
            <!-- <Matches container="matroska" aCodec="dca" /> -->
            <Matches container="matroska" aCodec="vorbis" />
            <Matches container="ogg" vCodec="mpeg4" />
            <Matches container="mp4" aCodec="lpcm" />
         <Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360" forceStereo="true">
            <Matches container="*" vCodec="mpeg2video" />
            <Matches container="*" vCodec="dvvideo" />
         <Audio targetContainer="mp3">
            <Matches container="*" />
         </Audio>
      <OnlineTranscoding>
         <Video targetContainer="applehttp"> <!-- dont transcode to ac3 -->
            <Matches container="mp4" />
            <Matches container="applehttp" vCodec="h264" />
      </OnlineTranscoding>
      <HardSubsTranscoding>
         <Video targetContainer="asf" targetVCodec="wmv2" targetACodec="wmav2" maxVBitrate="15360" forceStereo="true" />
      </HardSubsTranscoding>
      <Subtitles>
         <SoftSubs mime-type="text/srt" />
      </Subtitles>
I tested it on every type of video file I have MKV, MP4, WTV. These were DVD rips with MPEG2 video, BD rips with H.264 video, and Windows Media Center recorded TV with MPEG2. All these files were a mixture of SD and HD. All played both video and audio.
I just thought of one thing. The Chaneru developer was having problems with audio when using the analog connection instead of sending the audio over the HDMI cable. Any chance you are doing the same? And of course, your audio settings in the Roku are set to whichever audio put you are using. Sorry, simple question, but have to ask.
zika507
Post Fri Apr 04, 2014 2:47 am
atc98092 wrote:OK, here's my configuration. Roku 2 XS, firmware 5.4 build 3333. Roku Media PLayer version 4.1.0002. Serviio 1.4.1.2.
      <Detection>
         <HttpHeaders>
         </HttpHeaders>
      </Detection>
         </Audio>
      <OnlineTranscoding>
      <Subtitles>
      </Subtitles>
yes my friend i think that i have the same code that you have, everything is same like you but.. i only difference is my audio setting..
my roku audio setting is set to Stereo, and not via HDMI..! when i switch to send the audio via Hdmi, everything is gonna be working good!
thanks you a lot about that my friend..!
but.. the problem is i dont have a hdmi receiver, my home threather speaker system only accept the RCA stereo input!!! so i already check if the tv support external audio, but its not support that! damn! i already test everything but its impossible right now!
1.some solution about that my friend??
2.some code or setting to encode just the audio and send the audio via stereo too?
whats happen with the chaneru developers that u are mention it!
thanks you so much beforehand! i really appreciate every information and solution!
Post Sat Apr 05, 2014 1:35 am
So, your TV has no audio output? If that's the case, you may be stuck. If you do have TV audio out (either optical, coaxial, or even the analog left/right cables) I would send the video to your TV via HDMI and send the TV audio back to your theater system.
Without knowing your personal status, or even what country you are in, I won't presume to tell you to go buy a receiver with HDMI input/output capability. Here in the US they can be had for as little as a few hundred dollars, but I understand that even that may be too much for some people. And I have no idea what one would cost elsewhere. I don't know if the Chaneru developer ever resolved the audio issue without buying an AV receiver.
zika507
Post Mon Apr 07, 2014 4:46 am
well, i dont have a tv out mode,..! no stereo.. i have a panasonic plasma..! but, i dont know why not exist some solution to decode audio and sent it via Stereo!
Post Mon Apr 07, 2014 12:24 pm
zika507 wrote:well, i dont have a tv out mode,..! no stereo.. i have a panasonic plasma..! but, i dont know why not exist some solution to decode audio and sent it via Stereo!
I don't know which model you have, but my Panasonic plasma has an optical out, and that's what I use. Of course, my Roku is plugged into my AV receiver with HDMI, and the Roku audio set to surround. If you can plug the Roku into the plasma with HDMI, then feed the TV audio back with an optical cable to your audio receiver (I'm making an assumption that your receiver has an optical input), you should be able to set your Roku to surround audio and you should (hopefully) get sound.
Or do you mean you are not using any sort of AV receiver, and using the TV speakers for your sound? You should still be able to feed the TV your Roku output via HDMI, and set the Roku audio to surround.
syswalla
Post Sat Apr 12, 2014 8:14 pm
Hello all,
Just want to share something I worked on for the past two days which you've given me help to fix. I primarily use Serviio for audio files on a Ubuntu 12.04 LTS server and found the Roku 3 would not play MP3 audio files. They played fine using a Sony BluRay as well as when using Plex from the same server. However I really enjoy Serviio's Random Music function and wanted to get this to work.
The solution was changing the Roku's profile from "Roku Media Player" to "Generic DNLA profile".
Not sure why, but ffmpeg is having issues with MP3 and would throw the following error:
2014-04-12 13:36:46,152 WARN  [ProcessExecutor] Process ffmpeg has a return code of 137! This is a possible error. Detailed output follows.
frame=    1 fps=0.3 q=0.0 size=       0kB time=00:00:20.45 bitrate=   0.1kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:00:23.32 bitrate=   0.1kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:00:26.17 bitrate=   0.1kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:00:29.04 bitrate=   0.1kbits/s
frame=    1 fps=0.2 q=0.0 size=       0kB time=00:00:31.97 bitrate=   0.1kbits/s
I spent several hours updating and downgrading LAME, x264 and other libraries, as well as compiling and recompiling ffmeg from source, so I wanted to post this in case it helps someone else.
dluck
Post Wed Mar 04, 2015 5:23 pm
Just checking in here to see if anyone is listening in on this thread. We are working on an update to the serviio roku profile for Roku Media Player. Is anyone here interested in testing the changes out?
thanks
dale luck
roku
syswalla
Post Sun Mar 08, 2015 3:27 pm
I'd definitely be interested in a better Roku profile. I primarily use it for playing AAC & MP3 files so wouldn't be a good test case for video.
dluck
Post Mon Mar 09, 2015 8:38 pm
I suggest joining the Roku Media Player beta program if you are interested in helping to tune the profile.
Here is the current profile in testing:
This is the new one we are currently trying (work in progress):
<Detection>
<HttpHeaders>
</HttpHeaders>
</Detection>
<!-- Transcode if H.264 level is too high -->
<Video targetContainer="applehttp" targetVCodec="h264" maxVBitrate="12000" forceVTranscoding="true" targetACodec="aac" aBitrate="128" forceStereo="true">
<Matches container="*" vCodec="h264" profile="high_10" />
<!-- Transcode wmv,mpeg2video,... -->
<Video targetContainer="applehttp" targetVCodec="h264" maxVBitrate="12000" targetACodec="aac" aBitrate="128" forceStereo="true">
<Matches container="*" vCodec="wmv2" />
<Matches container="*" vCodec="mpeg1video" />
<Matches container="*" vCodec="msmpeg4" />
<Matches container="*" vCodec="h263" />
<Matches container="*" vCodec="h265" />
<Matches container="*" vCodec="mjpeg" />
<Matches container="*" vCodec="vp8" />
<Matches container="*" aCodec="dts-hd" />
<Matches container="*" aCodec="ac3" />
<Matches container="*" aCodec="truehd" />
<!-- Matches container="*" -->
</Audio>
<OnlineTranscoding>
<Subtitles>
</Subtitles>
donpearson
Post Sat Mar 14, 2015 10:07 am
Since the last update to 1.5.1 I seem to be having a lot of problems with my Roku 3, takes ages for videos to load (mp4), covers don't all load all the time and can't fast forward or rewind.
Could this be due to a profile change?
dluck
Post Sun Mar 15, 2015 12:41 am
Hi DonPearson,
I don't believe the profiles have changed, however there is a new Roku Media Player that turned off ff and rew for all transcoded files. are you interested in testing a beta version of the Roku Media Player? Are you a member of the Roku forums and would you be interested in joining the beta program for Roku Media Player?
dale
Users browsing this forum: Baidu [Spider] and 23 guests
