v.1.4.1 Panasonic Viera E30 .FLAC issue
nedds
Post Thu Mar 13, 2014 8:34 pm
after upgrading from v.1.4 to v.1.4.1, I'm not able to play .flac audio files on Panasonic Viera E30. The media server shows the correct list of the files with .flac extension but when trying to play it there is a message "the file isn't supported".
At this moment, I don't know are there any other issues/bugs with v.1.4.1.
Anyway, after reverting to v.1.4 the media server works as expected - the .flac audio is recognized and playable again.
Please check it out and correct this v.1.4.1 issue/bug.
Post Fri Mar 14, 2014 12:54 am
Re: v.1.4.1 Panasonic Viera E30 .FLAC issue
Will do. it was removed from the 2013 profile which, I assume, supports flas natively, but will add the transcoding back for 2012 and below
Post Fri Mar 14, 2014 5:07 am
Sorry - my mistake when blending the profiles. FLAC is naively supported in 2013 models.
nedds
Post Sun Mar 16, 2014 9:59 am
OK. Please advise when it'll be sorted out and safe to upgrade to 1.4.1.
Thx
Post Tue Mar 18, 2014 10:05 am
Users browsing this forum: Google [Bot] and 51 guests
