PS4 Browser Compatibility
Barbutus
Post Sat Mar 15, 2014 4:44 pm
Re: PS4 Browser Compatibility
yes, I have done some testing with my console, I was able to play some movies format. mkv.
Do not operate the buttons on the video window, "play" - "pause" - "full screen" - "Next" - "back", the only way to start the movie, is to start them all by clicking on "Play all "if you try too many times to press play, mediabrowser not responding to any commands, you must close the browser and reopen it.
I made ​​a video of my test, I'm loading up on youtube, in about 60 minutes I will link to this topic.
Sorry for my bad English, I'm using the google translator :)
spudy12
Post Sat Mar 15, 2014 4:57 pm
Thanks for your answer! All good helpful info. :)
Barbutus
Post Sat Mar 15, 2014 5:55 pm
here is the video of my test, I hope it is helpful, thanks for constantly improving this beautiful mediabrowser
http://youtu.be/plpG_NB8Fc8
Post Sun Mar 16, 2014 11:41 am
Thanks - looks like the control bar on PS4 is the problem, I cannot controll that. Unless it just doesn't work for transcoded content (live stream in the eyes on the PS4).
Can you try to set delivery quality on the Remote tab ot Best / Original and then play a mp4/h264/aac file, if you have one? That should play it without transcoding and as a usual HTML5 video.
Barbutus
Post Sun Mar 16, 2014 1:47 pm
Tested with MP4/H264/AAC file, the file plays correctly, here is the video of the test ...
http://youtu.be/o1HKvivT6J8
CompleteName                     : C:\h264_720p_mp_3.1_3mbps_aac_shrinkage.mp4
Format                           : MPEG-4
Format_Profile                   : Base Media / Version 2
CodecID                          : mp42
FileSize/String                  : 27,4MiB
Duration/String                  : 1min 10s
OverallBitRate_Mode/String       : Variabile
OverallBitRate/String            : 3.277 Kbps
Encoded_Date                     : UTC 2011-05-05 18:09:35
Tagged_Date                      : UTC 2011-05-05 18:09:35
Encoded_Library/String           : Apple QuickTime
ID/String                        : 1
Format_Profile                   : Main@L3.1
Format_Settings_CABAC/String     : Si
Format_Settings_RefFrames/String : 2 frame
CodecID                          : avc1
CodecID/Info                     : Advanced Video Coding
BitRate/String                   : 3.152 Kbps
BitRate_Maximum/String           : 3.500 Kbps
Width/String                     : 1.280 pixel
Height/String                    : 720 pixel
DisplayAspectRatio/String        : 16:9
FrameRate_Mode/String            : Costante
FrameRate/String                 : 29,970 fps
Standard                         : Component
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bit
ScanType/String                  : Progressivo
Bits-(Pixel*Frame)               : 0.114
StreamSize/String                : 26,3MiB (96%)
Language/String                  : Inglese
mdhd_Duration                    : 70037
ID/String                        : 2
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format_Profile                   : LC
CodecID                          : 40
BitRate/String                   : 124 Kbps
BitRate_Maximum/String           : 184 Kbps
Channel(s)/String                : 2 canali
ChannelPositions                 : Front: L R
SamplingRate/String              : 44,1 KHz
Compression_Mode/String          : Con perdita
StreamSize/String                : 1,03MiB (4%)
spudy12
Post Sun Mar 23, 2014 4:11 pm
I think this must be an issue with flowplayer rather than Serviio. If this is the case there is not alot that can be done I don't think.
Atleast, it is now working on the wii devices
grolschie
Post Sun Mar 23, 2014 8:08 pm
Hi. Just to add to the conversation. I have tested that demo page with the browser on the Panasonic E6, and the video won't load. However, I can open links to .m3u8 streaming TV files on this TV's web browser. Some play just fine. Some play but without sound though. The browser currently scores 333/555 on html5test.com, but I see no login box for the mediabrowser - just a black screen. I thought this was interesting, but the built-in DLNA player works just fine with Serviio. :D
Barbutus
Post Sat Sep 20, 2014 6:58 pm
Hi, there are no news?
I continued to test Serviio via the web browser of PS4, even after the latest system updates, but nothing has changed.
I tried a competitor media server via the browser of PS4, and this seems to work very well, but I want to continue to use Serviio also on my ps4 :(
I also tested Serviio on xboxone via DLNA by Media Player (beta), and it works great !
Previous
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 18 guests
