token of thanks to the developers
serviioadam
Post Sun Mar 23, 2014 11:21 pm
after years of hopelessly floundering with garbageware (7w0nky comes to mind, and p13x) i came across Serviio and it is the breaking of dawn across stormy skies. it is a limpid pool in the sahara. it is a sunlamp in the arctic.
i'm sure i'll have troubles now and again, but you have won a convert. sensible, configurable, small footprint, extendable: a fine piece of kit. you all should be proud, and i'll spread the word further.
i detest emoticons, but i will break with precedent here: :D
adam
Post Mon Mar 24, 2014 1:37 am
Re: token of thanks to the developers
:D
Return to General discussion
