OSX - Shoutcast plugin not functioning
serviioadam
Post Tue Mar 25, 2014 5:42 am
i've dug through all available on the topic, installed the plugin in the plugins folder, created the web resource call "http://www.shoutcast.com/" , specified Audio, saved. nothing appears under "Online Services."
everything else makes Serviio worth a good deal more than 25 bucks, and i appreciate it, but this plugin would improve the quality of my life. anybody know what's up? where IS the most current shoutcast plugin, anyway? mine is dated january 2013.
Post Tue Mar 25, 2014 5:31 pm
Re: OSX - Shoutcast plugin not functioning
there is a topic here, ask the dev there: viewtopic.php?f=20&t=4882
serviioadam
Post Wed Mar 26, 2014 1:16 am
i just asked there, but the developer hasn't posted in that thread since Sun Feb 24, 2013, so i'm not holding my breath. my guess is that since the emphasis here is on video streaming these days, shoutcast may not be a hot topic.
Post Wed Mar 26, 2014 9:26 am
The plugin devs are mostly independent devs, so obviously there is a possibility they move on. You can always PM them.
serviioadam
Post Wed Mar 26, 2014 1:03 pm
how about the tune-in radio plugin? that's b0rked too, and also, when i choose "Disable" under the "Presentation" tab, nothing is disabled. reducing onscreen clutter by removing unused icons is a fine idea. is the developer of those two items independent as well?
Post Fri Mar 28, 2014 12:36 am
Presentation only works for DLNA devices, not MediaBrowser.
TuneIn I can have a look when I have some time, but last time I checked, it was working and no one complained on the plugin thread. make sure you have the plugin from the thread, rather than from the All plugins pack.
serviioadam
Post Fri Mar 28, 2014 9:26 pm
thanks Petr, but i have good news. i fixed the plugin . tunein's output added escapes for a couple of quotes. i replaced this:
def stationMatcher = html =~ '(?s)<li class="clearfix play.*?">\\s*<a href="([a-zA-Z0-9-/]+)".*?<h3>(.*?)</h3>'
with this
def stationMatcher = html =~ '(?s)<li class=\"clearfix play.*?">\\s*<a href=\"([a-zA-Z0-9-/]+)".*?<h3>(.*?)</h3>'
and bingo! the modified plugin is uploaded here.
TuneIn.groovy
(5.56 KiB) Downloaded 339 times
serviioadam
Post Sat Mar 29, 2014 12:23 am
also zip, my groovy skills are minimal, but it shouldn't take you more than five minutes to craft a working shoutcast plugin from this:
http://www.shoutcast.com/radiolist.cfm? ... me%20Radio
where the "cat" argument is a genre (jazz, easy listening, etc.). the link to the .pls file is there for each station. (might be harder to parse the bit rate because it's a table with no CSS class to identify the bitrate.)
i wrestled with it for a while and gave up.
Xmantium
Post Sat Mar 29, 2014 8:29 am
You can organise the MediaBrowser icons by editing the contentDirectoryDef.xml found in serviio.jar\org\serviio\upnp\service\contentdirectory\definition\contentDirectoryDef.xml
so your most used categories appear first in MediaBrowser and ServiiGo
This is my screenshot:
Post Sun Mar 30, 2014 11:27 pm
serviioadam wrote:thanks Petr, but i have good news. i fixed the plugin . tunein's output added escapes for a couple of quotes. i replaced this:
with this
thanks, I uploaded it to the plugin's topic.
serviioadam
Post Mon Mar 31, 2014 8:19 pm
i wish the shoutcast thing were as easy. it LOOKS like it ought to be. the "new" site is built in ColdFusion, and a link like this:
http://www.shoutcast.com/radiolist.cfm? ... me%20Genre
...spits out a simple table with links of the form:
<a class="transition" href="http://yp.shoutcast.com/sbin/tunein-station.pls?id=12345">Some Station</a>
i have whittled the groovy code down to a nub, but i still can't get the #$%@& thing to work. i'm stumped, that output ought to be easy to grab. guess i don't understand string literals very well in Java.
the .cfm script doesn't supply a page <title> so that would have to come from the &cat= input.
Users browsing this forum: Google [Bot] and 18 guests
