Newer serviio versions can't play files that 0.6.2 can...
haplo
Post Sat Mar 29, 2014 12:57 am
Serviio is great, use it everyday, but this issue always stops me from upgrading from 0.6.2. I just tried 1.4.1.2, same problem.
My troubleshooting has been pretty basic. Fresh serviio install, default config, add sources, wait for scan to complete, attempt to play videos on Samsung TV: results in certain mkv videos throwing errors on the TV. I don't remember the exact error but it will be something like "invalid file format". When I turn serviio's transcoding setting off the error changes to "invalid audio format", again don't recall the exact verbiage but it's something about audio.
When I downgrade back to 0.6.2, default everything, the same file works perfectly.
It's a shame because I would like to make use of some particular features of the newest version.
I'm open to troubleshoot and debug, let me know what I can do to help.
wizb98y
Post Sat Mar 29, 2014 6:27 pm
Re: Newer serviio versions can't play files that 0.6.2 can..
I have issues similar to yours in the past.
I normally just replace the ffmeg binary with either
one that I build myself or a public build done by
someone else (you can search and download them...)
And the problems go away..
My 2 cents.
Post Sun Mar 30, 2014 1:36 am
haplo
Post Wed Apr 02, 2014 9:11 am
I'm running ubuntu server 12.04 and I would assume 1.4.1.2 and 0.6.2 would both use the installed (i.e. same) version of ffmpeg. Correct me if I'm wrong but his seems to eliminate ffmpeg as the culprit. The video uses something called 'TrueHD' for the audio track, I'm assuming this is somehow a problem since the error refers to "audio codec" (transcoding off).
Here is the requested information from ffmpeg:
ffmpeg version 0.8.10-4:0.8.10-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
  built on Feb  6 2014 20:56:59 with gcc 4.6.3
[matroska,webm @ 0x157d7a0] max_analyze_duration reached
[matroska,webm @ 0x157d7a0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (180000/1) -> 1000.00 (1000/1)
Input #0, matroska,webm, from '<filename removed>':
  Duration: 01:46:15.71, start: 0.000000, bitrate: 384 kb/s
    Chapter #0.0: start 0.000000, end 336.007100
      title           : Chapter 1
    Chapter #0.1: start 336.007100, end 509.013267
      title           : Chapter 2
    Chapter #0.2: start 509.013267, end 803.140433
      title           : Chapter 3
    Chapter #0.3: start 803.140433, end 902.072600
      title           : Chapter 4
    Chapter #0.4: start 902.072600, end 1186.022933
      title           : Chapter 5
    Chapter #0.5: start 1186.022933, end 1367.871267
      title           : Chapter 6
    Chapter #0.6: start 1367.871267, end 1962.131600
      title           : Chapter 7
    Chapter #0.7: start 1962.131600, end 2278.781267
      title           : Chapter 8
    Chapter #0.8: start 2278.781267, end 2456.458767
      title           : Chapter 9
    Chapter #0.9: start 2456.458767, end 2674.176267
      title           : Chapter 10
    Chapter #0.10: start 2674.176267, end 3074.576267
      title           : Chapter 11
    Chapter #0.11: start 3074.576267, end 3252.420600
      title           : Chapter 12
    Chapter #0.12: start 3252.420600, end 3549.050267
      title           : Chapter 13
    Chapter #0.13: start 3549.050267, end 3699.200267
      title           : Chapter 14
    Chapter #0.14: start 3699.200267, end 3768.436100
      title           : Chapter 15
    Chapter #0.15: start 3768.436100, end 3913.414267
      title           : Chapter 16
    Chapter #0.16: start 3913.414267, end 4056.056767
      title           : Chapter 17
    Chapter #0.17: start 4056.056767, end 4198.198767
      title           : Chapter 18
    Chapter #0.18: start 4198.198767, end 4388.722433
      title           : Chapter 19
    Chapter #0.19: start 4388.722433, end 4690.023433
      title           : Chapter 20
    Chapter #0.20: start 4690.023433, end 4864.531100
      title           : Chapter 21
    Chapter #0.21: start 4864.531100, end 5245.912100
      title           : Chapter 22
    Chapter #0.22: start 5245.912100, end 5593.092267
      title           : Chapter 23
    Chapter #0.23: start 5593.092267, end 5707.539933
      title           : Chapter 24
    Chapter #0.24: start 5707.539933, end 5893.058600
      title           : Chapter 25
    Chapter #0.25: start 5893.058600, end 6128.126767
      title           : Chapter 26
    Chapter #0.26: start 6128.126767, end 6375.712000
      title           : Chapter 27
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 1k tbr, 1k tbn, 180k tbc (default)
    Stream #0.1(eng): Audio: truehd, 48000 Hz, 5.1, s32 (default)
    Stream #0.2(eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.3(eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.4(jpn): Subtitle: pgssub
    Stream #0.5(eng): Subtitle: pgssub
    Stream #0.6(jpn): Subtitle: pgssub
    Stream #0.7(jpn): Subtitle: pgssub
    Stream #0.8(jpn): Subtitle: pgssub
    Stream #0.9(fre): Subtitle: pgssub
    Stream #0.10(ger): Subtitle: pgssub
    Stream #0.11(ita): Subtitle: pgssub
    Stream #0.12(ita): Subtitle: pgssub
    Stream #0.13(spa): Subtitle: pgssub
    Stream #0.14(dut): Subtitle: pgssub
    Stream #0.15(spa): Subtitle: pgssub
    Stream #0.16(por): Subtitle: pgssub
    Stream #0.17(dan): Subtitle: pgssub
    Stream #0.18(fin): Subtitle: pgssub
    Stream #0.19(nor): Subtitle: pgssub
    Stream #0.20(por): Subtitle: pgssub
    Stream #0.21(swe): Subtitle: pgssub
And here is the MediaInfo:
Unique ID                      : 188179284847270352221398605626166024212 (0x8D92030FD0BBC4D2913C9E9E846D1814)
Complete name                  : <filename removed>
Format                         : Matroska
Format version                 : Version 4 / Version 2
File size                      : 12.2 GiB
Duration                       : 1h 46mn
Overall bit rate mode          : Variable
Overall bit rate               : 16.4 Mbps
Encoded date                   : UTC 2013-12-09 02:42:16
Writing application            : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec  1 2013 17:55:00
Writing library                : libebml v1.3.0 + libmatroska v1.4.1
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings, CABAC         : Yes
Format settings, ReFrames      : 4 frames
Codec ID                       : V_MPEG4/ISO/AVC
Duration                       : 1h 46mn
Nominal bit rate               : 14.0 Mbps
Width                          : 1 920 pixels
Height                         : 1 080 pixels
Display aspect ratio           : 16:9
Frame rate mode                : Constant
Frame rate                     : 23.976 fps
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.282
Writing library                : x264 core 130 r2273 b3065e6
Encoding settings              : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=14020 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language                       : English
Default                        : Yes
Forced                         : No
Color primaries                : BT.709
Transfer characteristics       : BT.709
Matrix coefficients            : BT.709
Audio #1
Format                         : TrueHD
Codec ID                       : A_TRUEHD
Duration                       : 1h 46mn
Bit rate mode                  : Variable
Maximum bit rate               : 2 574 Kbps
Channel count                  : 6 channels
Channel positions              : Front: L C R, Side: L R, LFE
Sampling rate                  : 48.0 KHz
Compression mode               : Lossless
Language                       : English
Default                        : Yes
Forced                         : No
Audio #2
Format                         : AC-3
Format/Info                    : Audio Coding 3
Format profile                 : Dolby Digital
Mode extension                 : CM (complete main)
Format settings, Endianness    : Big
Codec ID                       : A_AC3
Duration                       : 1h 46mn
Bit rate mode                  : Constant
Bit rate                       : 192 Kbps
Channel count                  : 2 channels
Channel positions              : Front: L R
Bit depth                      : 16 bits
Compression mode               : Lossy
Stream size                    : 146 MiB (1%)
Language                       : English
Default                        : No
Forced                         : No
Audio #3
Format                         : AC-3
Codec ID                       : A_AC3
Duration                       : 1h 46mn
Bit rate                       : 192 Kbps
Bit depth                      : 16 bits
Language                       : English
Default                        : No
Forced                         : No
Text #1
Format                         : PGS
Codec ID                       : S_HDMV/PGS
Codec ID/Info                  : The same subtitle format used on BDs/HD-DVDs
Language                       : Japanese
Default                        : No
Forced                         : No
Text #2
Format                         : PGS
Language                       : English
Default                        : No
Forced                         : No
Text #3
Format                         : PGS
Language                       : Japanese
Default                        : No
Forced                         : No
Text #4
Format                         : PGS
Language                       : Japanese
Default                        : No
Forced                         : No
Text #5
Format                         : PGS
Language                       : Japanese
Default                        : No
Forced                         : No
Text #6
Format                         : PGS
Language                       : French
Default                        : No
Forced                         : No
Text #7
Format                         : PGS
Language                       : German
Default                        : No
Forced                         : No
Text #8
Format                         : PGS
Language                       : Italian
Default                        : No
Forced                         : No
Text #9
Format                         : PGS
Language                       : Italian
Default                        : No
Forced                         : No
Text #10
Format                         : PGS
Language                       : Spanish
Default                        : No
Forced                         : No
Text #11
Format                         : PGS
Language                       : Dutch
Default                        : No
Forced                         : No
Text #12
Format                         : PGS
Language                       : Spanish
Default                        : No
Forced                         : No
Text #13
Format                         : PGS
Language                       : Portuguese
Default                        : No
Forced                         : No
Text #14
Format                         : PGS
Language                       : Danish
Default                        : No
Forced                         : No
Text #15
Format                         : PGS
Language                       : Finnish
Default                        : No
Forced                         : No
Text #16
Format                         : PGS
Language                       : Norwegian
Default                        : No
Forced                         : No
Text #17
Format                         : PGS
Default                        : No
Forced                         : No
Text #18
Format                         : PGS
Language                       : Swedish
Default                        : No
Forced                         : No
Menu
00:00:00.000                   : en:Chapter 1
00:05:36.007                   : en:Chapter 2
00:08:29.013                   : en:Chapter 3
00:13:23.140                   : en:Chapter 4
00:15:02.072                   : en:Chapter 5
00:19:46.022                   : en:Chapter 6
00:22:47.871                   : en:Chapter 7
00:32:42.131                   : en:Chapter 8
00:37:58.781                   : en:Chapter 9
00:40:56.458                   : en:Chapter 10
00:44:34.176                   : en:Chapter 11
00:51:14.576                   : en:Chapter 12
00:54:12.420                   : en:Chapter 13
00:59:09.050                   : en:Chapter 14
01:01:39.200                   : en:Chapter 15
01:02:48.436                   : en:Chapter 16
01:05:13.414                   : en:Chapter 17
01:07:36.056                   : en:Chapter 18
01:09:58.198                   : en:Chapter 19
01:13:08.722                   : en:Chapter 20
01:18:10.023                   : en:Chapter 21
01:21:04.531                   : en:Chapter 22
01:27:25.912                   : en:Chapter 23
01:33:13.092                   : en:Chapter 24
01:35:07.539                   : en:Chapter 25
01:38:13.058                   : en:Chapter 26
01:42:08.126                   : en:Chapter 27
Post Thu Apr 03, 2014 5:12 pm
No, they dont't use the same versions. You need a new version, sources are on the website.
Users browsing this forum: Baidu [Spider] and 71 guests
