FF REW stopped working with new versions
Jimbob
Post Sun Mar 23, 2014 11:43 am
I have a Samsung UE40ES6540, I use the Samsung E/F Series profile, and with Transcoding disabled I could play all the media I need, and have FF and REW and general time seach options available in version 1.4
However since the updates, and I am not sure exactly which one 'broke' it, this has stopped working.
Also, I have downgraded back to 1.4 and it is still not working.
Any ideas anyone?
Jimbob
Post Mon Mar 31, 2014 8:27 am
Re: FF REW stopped working with new versions
Ive run one of the MKV's which was known working through the utils in the stickys, which made no difference at all.
I installed Samsung Link :( the new version of allshare, which is a truely nasty piece of software, but it DOES allow FF / REW jump arrows to work with my media.
Id love to know whats gone wrong with serviio for me, I suspect I will be doing a removal and reinstall with a variety of versions to see if that helps.
Watch this space.
Post Mon Mar 31, 2014 6:15 pm
Make sure you have the right profile selected.
Jimbob
Post Tue Apr 01, 2014 1:01 pm
Ok, been playing.
Tv is a Samsung UE40ES6450
Ive gone back to 1.3.1
Using profile Samsung TV / player (C/D/E/F-Series)
With Transcoding off, I have search facilities
When I enable transcoding I loose it again. (no problem, expected behavior)
Version 1.4
Using profile Samsung TV / player (C/D-Series)
Whichever Transcoding setting I use, I have no search
Using profile Samsung TV / player (E/F-Series)
Version 1.4.1.2
With Transcoding off, I have search facilities back again!
Now, Why its working again, I have no idea, as all the setting are back EXACTLY as they were when the issue first arose, why 1.4 wouldnt give me search I have no idea.
As long as they stay back, Im happy :)
