Hardware requirements for transcoding ?
Danthuyer
Post Mon Feb 07, 2011 1:45 am
Please forgive me if this is covered elsewhere or point me to a link.
I would like to know if there are any issues with me trying to run transcoding with the following hardware:
HP SFF PC:
Pentium 4 HT
2 Gb DDR Memory
Plenty of disk space (@ 2TB)
Playstation 3:
AUS Spec 120Gb
Wireless Ethernet
Wireless Router:
802.11G
I am going to be transcoding .rmvb files into my the PS3 so that I can watch some anime without impacting on the wifes TV (Brownie Points !!)
This box handles the serving of normal .avi .mkv files via Ethernet/wireless however this is the first time I will be attempting to transcode. So it would be good to know if the machine or the network will be the bottleneck here if any.
Dan !
Post Mon Feb 07, 2011 1:51 am
Re: Hardware requirements for transcoding ?
nope you should be fine with that setup :)
Danthuyer
Post Mon Feb 07, 2011 1:56 am
Excellent news !
I just had a quick look around to see if there were any profiles existing in here for PS3 ?
I don't have the SW here at work with me .... does 0.5 have a PS3 pre defined profile ? or Do I need to create a new one ?
Post Mon Feb 07, 2011 2:03 am
Danthuyer wrote:Excellent news !
yep it there by default and works great from my testing :)
Post Mon Feb 07, 2011 9:17 am
but rmvb files are not supported. Can you post ffmpeg -i <file> for a few of those?
Danthuyer
Post Mon Feb 07, 2011 9:58 am
hey zip happy to help
i take it thats just a CLI you want me to use and post the output ?
Post Mon Feb 07, 2011 9:59 am
yep.
Danthuyer
Post Mon Feb 07, 2011 10:05 am
does this look right ??
C:\Program Files (x86)\Serviio\lib>ffmpeg -i "e:\TV Shows\Initial D\First Stage\
Initial D First Stage - Act 1.rmvb"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[NULL @ 03056850] Unsupported video codec
[rm @ 011ebd30] max_analyze_duration reached
Input #0, rm, from 'e:\TV Shows\Initial D\First Stage\Initial D First Stage - Ac
t 1.rmvb':
title : Ep 01: Ultimate Tofu Guy Drift
author : midoban: http://www.da-anime.org
copyright :
comment :
Duration: 00:24:55.36, start: 0.000000, bitrate: 263 kb/s
Stream #0.0: Audio: cook, 44100 Hz, stereo, s16, 64 kb/s
Stream #0.1: Video: rv40, yuv420p, 512x384, 192 kb/s, 12.05 fps, 12 tbr, 1k
tbn, 12 tbc
Stream #0.2: Data: [0][0][0][0] / 0x0000
Post Mon Feb 07, 2011 11:15 am
yes, thanks
there was already open ticket: https://bitbucket.org/xnejp03/serviio/i ... ding-files
Danthuyer
Post Mon Feb 07, 2011 11:16 am
happy to help
let me know if you need anything else.
