PS3 transcoding stuttering
bergOpolis
Post Tue Apr 01, 2014 7:22 am
NOTE: I've searched the forum and found several similar posts, but most don't have a clear (to me, at least) resolution and end up with the Mod asking for detailed file/log info particular to the case. So I'm just going to go ahead and describe my problem and give all the relevant data I can.
It seems that it is a common enough problem. I'm using a PS3 as a rendering device and it is "stuttering" on many videos. The problem isn't limited to only MKV files and it seems that sometimes the video is issue and sometimes the audio.
First I am running the Serviio (1.4.1.2) server on my MacBook Pro:
Processor  2.66 GHz Intel Core 2 Duo
Memory  8 GB 1067 MHz DDR3
Graphics  NVIDIA GeForce 9600M GT 256 MB
Software  OS X 10.9.2
It is a wired network.
I can't list info for every file I have an issue with so I guess I'll choose the most recent I've had problems with (let me know if it a bad example for some reason).
In this case the audio plays flawlessly while the video just speed skips between stills:
Complete name                            : Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg)/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv
File size                                : 907 MiB
Duration                                 : 1h 31mn
Overall bit rate                         : 1 383 Kbps
Writing application                      : HandBrake 0.9.9
Writing library                          : libmkv 0.6.5
Format profile                           : High@L4.0
Format settings, ReFrames                : 8 frames
Duration                                 : 1h 31mn
Nominal bit rate                         : 1 250 Kbps
Height                                   : 694 pixels
Display aspect ratio                     : 1.85:1
Bits/(Pixel*Frame)                       : 0.059
Writing library                          : x264 core 130 r2273 b3065e6
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.10 / mixed_ref=1 / me_range=30 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1250 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Codec ID                                 : A_AAC
Duration                                 : 1h 31mn
Detailed log:
2014-04-01 09:04:15,763 DEBUG [ResourceDeliveryProcessor] Request for resource 24 and type 'MEDIA_ITEM' received
2014-04-01 09:04:15,763 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-01 09:04:15,763 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-01 09:04:15,764 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-01 09:04:15,764 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 24, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2014-04-01 09:04:15,765 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv
2014-04-01 09:04:15,765 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: AVC_TS_MP_HD_AC3_ISO
2014-04-01 09:04:15,765 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-01 09:04:15,765 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-01 09:04:15,766 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-01 09:04:15,771 DEBUG [VideoDeliveryEngine] Delivering item '24' for client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 09:04:15,771 DEBUG [VideoDeliveryEngine] Delivering file 'Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv' using transcoding
2014-04-01 09:04:15,772 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 09:04:15,772 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-04-01 09:04:15,772 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: AVC_TS_MP_HD_AC3_ISO
2014-04-01 09:04:15,772 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 24) as read
2014-04-01 09:04:15,773 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-04-01 09:04:15,773 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-04-01 09:04:15,774 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-04-01 09:04:15,774 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Tue, 01 Apr 2014 07:04:15 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5503/5503,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-04-01 09:04:43,547 DEBUG [SearchManager] Committing search index
2014-04-01 09:04:48,555 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.13:59544s
2014-04-01 09:04:49,044 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.0.13:59544s
2014-04-01 09:04:57,760 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-04-01 09:04:57,760 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-04-01 09:05:13,615 DEBUG [SearchManager] Committing search index
2014-04-01 09:05:16,127 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Is it a hardware issue? can my MBP just not handle transcoding on the fly? It says the transcoding is finished, but I'm not clear on all the details of the process.
FYI, I tried deleting the STF file before selecting the file for the purposes of detail logging, but it still says "A suitable transcoding job already exists".
Post Tue Apr 01, 2014 8:11 am
Re: PS3 transcoding stuttering
Sometime with my old Sony Bravia 2010, some h264 remux have stuttering, but I don't know why..h264 encoding settings that sony does not support?!
So I create a custom profile that transcode h264 to mpeg2video that I selected for this particular file.
For your PS3, you can try this one:
Copy/Paste in profiles.xml file just before the last </Profiles> element. Restart serviio services or reboot PC, then manually select the custom profile on serviio console.
You can change profile before viewing other files.
<Profile id="ps3fix" name="Playstation 3 - h264*" extendsProfileId="4">
         <!-- Transcode MKV/h264 -->
         <!-- remove DAR option on next line for U.S. model -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" DAR="16:9" forceInheritance="true">
            <Matches container="*" vCodec="h264" />
Post Tue Apr 01, 2014 8:37 am
It would be better if we could see the detailed log showing the ffmpeg command being invoked - you need to clear the transcode cache so that we can capture this. Rather than simply deleting the transcoded stf file (which is not normally a good idea), restart your Serviio service (or better, restart the Mac).
Also if you remux the file to MP4 does it continue to stutter? To remux use the command: ffmpeg - i filename.mkv -c copy -map 0 filename.mp4 and try the resultant mp4 file.
bergOpolis
Post Tue Apr 01, 2014 2:51 pm
Thanks for the advice IIlico. I might give that a try later.
DenyAll:
Here is the detailed log with the ffmpeg command -
2014-04-01 16:25:10,210 DEBUG [ResourceDeliveryProcessor] Request for resource 24 and type 'MEDIA_ITEM' received
2014-04-01 16:25:10,210 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-01 16:25:10,210 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-01 16:25:10,225 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-01 16:25:10,225 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 24, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2014-04-01 16:25:10,226 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv
2014-04-01 16:25:10,226 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: AVC_TS_MP_HD_AC3_ISO
2014-04-01 16:25:10,227 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-01 16:25:10,227 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-01 16:25:10,227 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-01 16:25:10,228 DEBUG [VideoDeliveryEngine] Delivering item '24' for client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 16:25:10,229 DEBUG [VideoDeliveryEngine] Delivering file 'Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv' using transcoding
2014-04-01 16:25:10,229 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 16:25:10,229 DEBUG [MediaItemDAOImpl] Getting file of media item 24
2014-04-01 16:25:10,230 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /Users/bergOpolis/Documents/Vuze Downloads/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg)/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv
2014-04-01 16:25:10,231 DEBUG [ProcessExecutor] Starting /Applications/serviio/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -fflags +genpts -threads auto -i /Users/bergOpolis/Documents/Vuze Downloads/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg)/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv -y -threads auto -c:v copy -bsf:v h264_mp4toannexb -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zd/vvb83yl16qq3rvgbksdvph9r0000gn/T/Serviio/transcoding-temp-24-4-ORIGINAL.stf
2014-04-01 16:25:10,805 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-04-01 16:25:10,807 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: AVC_TS_MP_HD_AC3_ISO
2014-04-01 16:25:10,807 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 24) as read
2014-04-01 16:25:10,863 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-04-01 16:25:10,863 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-04-01 16:25:10,863 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-04-01 16:25:10,863 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Tue, 01 Apr 2014 14:25:10 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5503/5503,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-04-01 16:25:12,199 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-04-01 16:25:12,200 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-04-01 16:25:12,809 DEBUG [WebServer] I/O error: Broken pipe
2014-04-01 16:25:12,815 DEBUG [ServiioHttpService] Incoming request from /192.168.0.12:58921: GET /resource/24/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.0.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,TimeSeekRange.dlna.org: npt=0.000-,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2014-04-01 16:25:12,818 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-04-01 16:25:12,819 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.12
2014-04-01 16:25:12,819 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 16:25:12,819 DEBUG [ResourceDeliveryProcessor] Request for resource 24 and type 'MEDIA_ITEM' received
2014-04-01 16:25:12,819 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-01 16:25:12,819 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-01 16:25:12,820 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-01 16:25:12,821 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 24, format AVC_TS_MP_HD_AC3_ISO and profile Playstation 3
2014-04-01 16:25:12,821 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv
2014-04-01 16:25:12,822 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: AVC_TS_MP_HD_AC3_ISO
2014-04-01 16:25:12,822 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-01 16:25:12,822 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-01 16:25:12,823 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-01 16:25:12,823 DEBUG [VideoDeliveryEngine] Delivering item '24' for client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 16:25:12,824 DEBUG [VideoDeliveryEngine] Delivering file 'Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv' using transcoding
2014-04-01 16:25:12,824 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.0.12, Profile=Playstation 3'
2014-04-01 16:25:12,824 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-04-01 16:25:12,825 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: AVC_TS_MP_HD_AC3_ISO
2014-04-01 16:25:12,825 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 24) as read
2014-04-01 16:25:12,893 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-04-01 16:25:12,893 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-04-01 16:25:12,893 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-04-01 16:25:12,893 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Tue, 01 Apr 2014 14:25:12 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5503/5503,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-04-01 16:26:12,266 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-04-01 16:26:12,266 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2014-04-01 16:26:26,053 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Also remuxing the file manually to MP4 solves the stuttering problem.
What is the best long term solution for this? Should I alter the PS3 profile in someway? Can that remuxing be done "on the fly" or at least right before the video plays? It didn't take very long.
Post Tue Apr 01, 2014 6:34 pm
Transcoding on the fly to mp4 container is not supported by serviio.
But you can do it manually with ffmpeg.
Then my custom profile should also do the job.If you have problem with one file, open serviio console, manually select the custom profile.
Then on next time or at the end oh the file, come back to the official profile.
bergOpolis
Post Wed Apr 02, 2014 4:11 pm
Illico -
I tried out your strategy and after I attempt to open the file I get an unsupported data type error.
This is the associated log:
2014-04-02 18:01:24,527 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 24 (local)
2014-04-02 18:01:24,527 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 24)
2014-04-02 18:01:24,528 DEBUG [VideoDAOImpl] Reading a Video (id = 24)
2014-04-02 18:01:24,529 DEBUG [VideoDeliveryEngine] Delivering item '24' for client 'Identifier=192.168.0.12, Profile=Playstation 3 - h264*'
2014-04-02 18:01:24,529 DEBUG [VideoDeliveryEngine] Delivering file 'Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv' using transcoding
2014-04-02 18:01:24,529 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.0.12, Profile=Playstation 3 - h264*'
2014-04-02 18:01:24,530 DEBUG [MediaItemDAOImpl] Getting file of media item 24
2014-04-02 18:01:24,531 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /Users/bergOpolis/Documents/Vuze Downloads/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg)/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv
2014-04-02 18:01:24,532 DEBUG [ProcessExecutor] Starting /Applications/serviio/Serviio.app/Contents/Resources/Java/../../MacOS/ffmpeg -threads auto -i /Users/bergOpolis/Documents/Vuze Downloads/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg)/Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv -y -threads auto -c:v mpeg2video -pix_fmt yuv420p -b:v 17000k -maxrate:v 17000k -bufsize:v 17000k -vf pad=1280:720:0:13:black,setdar=4:3 -r 24000/1001 -g 15 -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /var/folders/zd/vvb83yl16qq3rvgbksdvph9r0000gn/T/Serviio/transcoding-temp-24-ps3fix-ORIGINAL.stf
2014-04-02 18:01:25,103 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-04-02 18:01:25,105 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: MPEG_TS_SD_EU_ISO
2014-04-02 18:01:25,105 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: MPEG_TS_SD_NA_ISO
2014-04-02 18:01:25,105 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bottle Rocket (1996) 720p.BRrip.Sujaidr (pimprg).mkv: MPEG_TS_SD_KO_ISO
2014-04-02 18:01:25,105 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 24) as read
2014-04-02 18:01:25,121 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-04-02 18:01:25,121 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-04-02 18:01:25,121 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2014-04-02 18:01:25,121 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Date: Wed, 02 Apr 2014 16:01:25 GMT,Server: Mac OS X, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,TimeSeekRange.dlna.org: npt=0-5503/5503,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-04-02 18:01:25,941 DEBUG [SearchManager] Committing search index
2014-04-02 18:01:27,365 DEBUG [WebServer] I/O error: Broken pipe
2014-04-02 18:01:56,185 DEBUG [SearchManager] Committing search index
so it is a different ffmpeg call using the new profile, but I guess it creates something that my PS3 can't read as a result?
Thanks in advance for helping to walk me through this.
EDIT : I suppose I could find some utility that will batch process ffmpeg commands and I can just use DenyAll's strategy on all the files that are troublesome... or just get more fluent at using the command line. So there is no way to set up a profile that will call the ffmpeg - i filename.mkv -c copy -map 0 filename.mp4 command? Maybe a plugin for Serviio? It really only took my computer seconds to run that command, I'd be willing to wait that long before a video plays...
Post Thu Apr 03, 2014 1:01 am
Batch process the ffmpeg command - if you were a Windows user my tool here will do it (use the Remux tab, set to remux from MKV to MP4): viewtopic.php?f=17&t=12136. As a MAC user you may have to write something yourself.
No, Serviio cannot transcode on the fly to an MP4 container.
Users browsing this forum: Bing [Bot] and 3 guests
