Error 500, partial loss of library
Jimbob
Post Thu Apr 03, 2014 12:53 pm
I had been reinstalling serviio a few times around a different issue.
I have gone to play a video, and the one I wanted is no longer in the library, along with many others now missing.
An example of a missing file from the log is :
2014-04-03 13:09:01,389 WARN [LibraryUpdatesCheckerThread] Cannot update file Doctor Who 2005 - 1x00 - Christmas Invasion (Xmas special 2005) in library because of an unexpected error. Message: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
java.lang.IllegalArgumentException: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
at java.lang.Enum.valueOf(Unknown Source)
at org.serviio.library.local.metadata.MPAARating.valueOf(MPAARating.java:16)
at org.serviio.library.dao.VideoDAOImpl.initVideo(VideoDAOImpl.java:1334)
at org.serviio.library.dao.VideoDAOImpl.mapSingleResult(VideoDAOImpl.java:1257)
at org.serviio.library.dao.VideoDAOImpl.read(VideoDAOImpl.java:169)
at org.serviio.library.dao.VideoDAOImpl.read(VideoDAOImpl.java:53)
at org.serviio.library.local.service.VideoService.getVideo(VideoService.java:326)
at org.serviio.library.local.service.VideoService.updateVideoInLibrary(VideoService.java:214)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.updateMetadata(LibraryUpdatesCheckerThread.java:269)
at org.serviio.library.local.metadata.LibraryUpdatesCheckerThread.run(LibraryUpdatesCheckerThread.java:113)
The serviio interface also gives the message An unexpected error occured (500) check the log
which shows
2014-04-03 13:49:37,082 WARN [ServiioStatusService] IllegalArgumentException occured. Returning error code 500 to the REST layer. Message: No enum constant org.serviio.library.local.metadata.MPAARating.Unknown
Any ideas?
Post Thu Apr 03, 2014 5:15 pm
Re: Error 500, partial loss of library
It looks like you possibly downgraded? If that's the case, it's not supported and will break your installation. You'd have to install it again from scratch.
Jimbob
Post Fri Apr 04, 2014 12:47 pm
Yes, had downgraded, upgraded, generally swapped versions like hell.
Anyway, fully removed, rebooted, reinstalled,
Full media library is back, and working correctlt, including time search functions..
