Use of Multi Devices
• Page 1 of 1
I have a Sony 55HX8000 and a PS3. Both work well with Serviio. Serviio is running on a Windows server 2003 R2 file server. I have notice that if I view content from one of the devices that the 2nd device will fail to find the Serviio server until after I reset the Serviio. Does anyone else see this? Is there a way to use these devices interchangeably and or at the same time? Your help will be appreciated.
Re: Use of Multi Devices
i have had up to 3 devices all using serviio at same time. 2x samsung pc's and a ps3.
Thank you for your the insight - I'm wondering if it's a Windows Server Issue? Additionally the computer is only a 1.8GHZ AMD single core w/ 2GB RAM. You think I need more machine? BTW I am streaming .VOB if that's a possible issue. I really like the simplicity and straight forwardness of Serviio and I have recommended to others- I really want this multi device inconvenience resolved any ideas?
So if you browse for files on one device (not playing), can you browse on the other at the same time?
Petr
Help translate Serviio
Actually the folder structure is there but the files are not displayed. When I return to the first device the files are still there - almost like a sharing issue but all the files in the folder disappear not just the opened file. Any Ideas? Thank You again
It goes like this…
I browse using my TV – the files and folders are displayed as normal and I play the content as normal. I attempt to use the PS3 then the folders are all there but no files regardless of what folder look in. If I restart Serviio and the other devices then I can browse and view content with the PS3 but not the TV. It depends on which DLNA device I start first after the Serviio restart.
I hope that make sense - I really appreciate your help.
can you post the detailed log catching this behaviour (will probably be big, zip it up and attach here)
Petr
Will do but it will need to be later... Was there any particular format you wanted the log in?
just zip it up (.zip)
Petr
Thank you zip for your help but, after I did a cold boot of the server now everything is working as it should. Both devices connect at the same time and interchangeably- I'm guessing it was a Windows server issue all along the way.
Many thanks again
Many thanks again
Roland wrote:Thank you zip for your help but, after I did a cold boot of the server now everything is working as it should. Both devices connect at the same time and interchangeably- I'm guessing it was a Windows server issue all along the way.
Many thanks again
that is good news, i have been watching this thread and trying to work out why i could do it and you could not, glad you got it sorted
Cool. There still might be a hidden bug somewhere, so if it happens again please report
Petr
i just tried this about 20mins ago great mind think alike zip i managed to stream the same movie file to 3 devices independantly all at the same time
2x samsung le40c750 tvs and a ps3 all playing the same movie but at different stages of the movie, proving that its working and work great.
Thank you both for your assistance - I will keep monitoring it to see if it reoccurs and what series of events lead to it. Thanks Again!!!
Hi Guys,
Just joined! I have been using Serviio no probelms with my Sony Blu Ray player but now that i have the Xbox 360 connected I am having problems! The Xbox can't connect to the server! It seees the network fine but just won't connect! how do I do a cold boot of the server? would that fix it?
manjab14 wrote:Hi Guys,
Cold Boot = turn the pc running serviio off at the mains
Check your network settings are correct and that both the xbox and serviio are on the same network and is the XBOX running wirelessly as the xbox wireless system is rubbish and run much better when hardwired.
• Page 1 of 1
