Serviio doesn't brodcast SOPCAST
xarlo
Post Fri Apr 04, 2014 4:29 pm
Hello to everybody,
I have a problem with Sopcast & Serviio. I downloaded the last version of Serviio, installed it and added the plugins BUT, when I try to broadcast an online resource with Sopcast, my TV only show an empty folder.
By the way, if I broadcast a file from my computer (typically a film) everything works well.
With some previous releases (both of Serviio and Sopcast) I had no problem.
May be I use an old Sopcast plugin??? (I'm using Sopcast 3.8.3 with Windows 7 OS).
Thanks to the experst for the support
Bye
Xarlo
Post Fri Apr 04, 2014 8:46 pm
Re: Serviio doesn't brodcast SOPCAST
There is no Sopcast 3.8.3 plugin.
xarlo
Post Sat Apr 05, 2014 8:41 am
Thanks for your explanation.
By the way, do you know which is the last version of Sopcast that works with Srviio?
And which is the last working Sopcast plugin????
Thank you again to all the experst
Bye
Xarlo
Users browsing this forum: Google [Bot] and 19 guests
