File won't play, won't add - any ideas :)
falcon15500
Post Fri Apr 04, 2014 8:23 am
HI all,
As per the title, I have a file that won't play. Actually - it won't even show up in the library. The output from the serviio logfile is:
 2014-04-04 19:03:15,435 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/mnt/movies/Hobbit.The.Desolation.of.Smaug,.The.(2013)-tt1170358/The.Hobbit.The.Desolation.of.Smaug.mkv). Message: Unknown video codec.
Output of ffprobe is here: http://www.nine-hells.net/ffp.txt
Output of mediainfo is here: http://www.nine-hells.net/mi.txt
Any suggestions would be great.
M.
Post Fri Apr 04, 2014 3:21 pm
Re: File won't play, won't add - any ideas :)
HEVC not supported yet by serviio.
And I'm not sure that your device renderer support it.
falcon15500
Post Fri Apr 04, 2014 10:14 pm
Well that was easy enough! Thanks for the info. Guess I will have to try to transcode it somehow (not very knowledgable about such things).
M.
Post Sat Apr 05, 2014 6:59 am
HEVC(h265) is the latest video encoding format that will be used in the next years. It's better than AVC(h264) and will be used for next 4K resolution on professional video broadcasting.
I think that ZIP could add this format on video matching, then it'll be added on serviio library, so you can add it on profile to transcode it.
I will open a ticket... https://bitbucket.org/xnejp03/serviio/i ... e-matching
Xmantium
Post Sat Apr 05, 2014 3:24 pm
The latest ffmpeg support x265 too
Jyrx
Post Wed Apr 30, 2014 3:12 pm
HEVC (h265) is supported on Samsung TV 2014 H-models (but not by Serviio jet).
Tested on UE40H6200 and UE55HU7500 (USB HDD).
Also h264 Hi10 and h264 HP up to L 5.1 supported, tested on Serviio NAS too,
no transcoding needed.
Users browsing this forum: No registered users and 66 guests
