Large Cover Images
Allensbad
Post Fri Apr 04, 2014 10:34 pm
Large Cover Images
Hi All,
I hope this is the right place for this question.
I am working on a Digital Media Controller (DMC) and was wondering if it was possible to get larger cover images in a browse request?
I don’t know if its just the dlna spec but seems all I can get for cover are get are images that are 106 x 160, is this all that is available?
Regards
Al
Post Sat Apr 05, 2014 9:08 am
Re: Large Cover Images
you can get 320x320 if you use HD as the thumbnail size in a given profile.
Allensbad
Post Sat Apr 05, 2014 2:41 pm
Great,
I'll give it a try.
Al
baumleipzig
Post Fri Sep 17, 2021 8:47 am
Allensbad wrote:
I will try that, thanks. But I'll also need to
write my essay fast and choose my paper book thumbnail image.
So 320x320 is the maximum size, right? I thought I may ask someone to help me out with the cover images in my Cover Art Resolutions project.
Post Fri Sep 17, 2021 7:00 pm
This thread is over 7 years old, and isn't completely accurate now. Serviio supports higher quality images than 320, but to use them you need to add a new line in the user.vmoptions file under the Serviio/config folder. I have added "-Dserviio.hdThumbnailResolution=1000" to mine, and the thumbnail images are very high quality. Just remember that increasing the image quality requires more space in the Serviio database (which stores the images). Nothing drastic, just something to remember. My database folder is using about 240 MB, with the setting above and about 5700 titles in my library.
Users browsing this forum: Google [Bot] and 13 guests
