[SOLVED] No-go on Samsung UE46B7020
Lucien
Post Mon Feb 07, 2011 8:51 am
Hey there, thank you for this great program, but i can't get it to show on my Samsung Led tv.
But Serviio recognized my tv.. i tried everything in you f.a.q. , port forwarding in my router, bound ip adress to the PC where Serviio runs on and i still can't get it to work.
Only when i reboot my router than the tv sees Serviio, but i can't play any files..
Can someone please explain to me what is going wrong? :)
Post Mon Feb 07, 2011 9:58 am
Re: No-go on Samsung UE46B7020
post the log
Lucien
Post Mon Feb 07, 2011 10:02 am
Thank you, here it is..
And a image of the program running, if it helps..
Post Mon Feb 07, 2011 11:04 am
I'm not sure if you have to do port forwarding on the router as we're only talking on LAN. You could revert it and just make sure there is no firewall on your PC blocking 8895. Try that and enable detailed log, then post the result.
Lucien
Post Mon Feb 07, 2011 10:08 pm
Sorry, i tried everything... and still my tv does not see Serviio..
I reverted my routers firmware from dd-wrt to stoch firmware. I have a TP-Link WR1043ND, but that doesn't help either.
I opened the ports on my firewall, after that i completely disabled the windows firewall and still nothing.
The tv does see dlna from windows 7
Thanks for your time. :)
Lucien
Post Mon Feb 07, 2011 10:25 pm
I finally solved it, i'm such an idiot.
I forgot to enable a setting in windows :oops:
Your program works great now, thank you very much for your time and effort.
Forgot to enable this....
