Web UI in PHP - support thread
Xmantium
Post Sun Apr 06, 2014 10:52 pm
Re: Web UI in PHP (revised)
Hi Swoop, seems to me few issues with Pro licence upload, I tried it too and some few posts in the QNAP forums
Swoop
Post Tue Apr 08, 2014 6:22 pm
Hm, will try to check it out on the weekend. I'm currently on business travel.
ertyu
Post Thu Apr 24, 2014 1:03 am
I just installed the webui and I can't seem to get any settings to save. They say saved, but if I go back and look they aren't. I can't find any errors in the serviio log or web logs. What could be going wrong?
Swoop
Post Mon Apr 28, 2014 9:10 pm
could you let me know which webUI version you're using and which Serviio version? Also, you might want to consider turning on the two debugging parameters in config.php to get some further hints.
ertyu
Post Mon Apr 28, 2014 9:16 pm
I'm running Serviio 1.4.1 with the webui for 1.4 02/09/2013 - Revised for Serviio 1.4 (Updated by SwoopX).
I've tried the debug options in the config file, and they didn't display anything that seemed relevant.
ertyu
Post Thu May 01, 2014 2:10 am
I guess I'm actually running 1.5.4 of the WebUI
ertyu
Post Thu May 01, 2014 2:47 am
I turned on debugging in serviio itself. I'm not seeing the /rest activity from the webui writing back to it. I do see a response in the log if I hit it with curl, a forced library rescan for example.
Swoop
Post Sat May 03, 2014 9:37 pm
I'd assume then that you're using webUI version 1.5.4.
Actually, the debug output is relevant unless you get something like the below after having saved data:
<result>
  <errorCode>0</errorCode>
</result>
This is the regular output after having saved the settings successfully.
Are you running Serviio on a NAS? I presume this is not the case.
ertyu
Post Sat May 03, 2014 10:20 pm
It's a file server, but a full pc and not an embedded nas.
I get debug output like this in the web console:
Sat May 03 2014 17:21:53 GMT-0500 (Central Standard Time)
process=save tab=delivery process=save transcoding=1 location=/tmp/ cores=2 quality=1 audio=downmix subtitles=1 characterEncoding=UTF-8 language=
Response data
HTTP response code: 200
Swoop
Post Sun May 04, 2014 11:31 pm
Hm, really weired. Looks like the backend is doing nothing...
Maybe it's worth a try to give the whole webUI directory full permissions. If you know how to handle TCPDump, it would also be very interesting to see what the REST communication looks like for that, you need to listen on 127.0.0.1. The 200 response code just indicates that the backend has received the request with the config parameters. The real deal is a XML response in the debug area. I'd expect the REST response is a 500...
ertyu
Post Mon May 05, 2014 11:09 pm
I'm not seeing an XML response anywhere. Fired up tcpdump on loopback. I see the GET requests to REST, but there are no POST transactions during a save. Tired changing the file/directory permissions, no change.
Swoop
Post Sun May 11, 2014 9:08 pm
There should be a PUT request during save. If its not there I have some doubts serviio is running flawlessly on your system or the backend is somehow prevented to communicate with Serviio properly :(
Post Wed Sep 03, 2014 9:31 am
Can we fix the license upload bug? I'm getting quite a few people complaining their license doesn't work. I can send you a license to test with if you want.
Xmantium
Post Wed Sep 03, 2014 8:39 pm
Few reports on QNAP forums about this too but it worked fine for me
Big bug i have - "Start Server" button does not work
Zip have you decided Serviio using its own web UI or the Java FX route?
Post Thu Sep 04, 2014 12:36 pm
re web ui: probably a web app, but still not planned for any forseable future
haplo
Post Thu Oct 30, 2014 9:17 pm
RE: license upload bug
Please fix this issue, I just bought a license and I can't get it to update serviio. When I click the Load New License button and select the license file, a caption appears under the button that says "Data imported!" but the About page still reports the following:
Serviio PRO v 1.4.1.2 EVALUATION license - WebUI v 1.5.4
Licensed To: ()
Edit: I was able to upload it via the command line method: http://forum.serviio.org/viewtopic.php?p=50586#p50586
Swoop
Post Sat Nov 01, 2014 12:44 am
Has just been fixed and uploaded ;)
PhAzE
Post Fri Jan 16, 2015 4:01 pm
Does this work with serviio 1.5? I was using some other webui and it doesn't look to be updated anymore, so if I switch to this one, does it need apache installed to work or does it have a built in portable webserver?
Swoop
Post Sun Jan 25, 2015 9:51 pm
Hi phAzE,
take a look at http://forum.serviio.org/viewtopic.php?f=17&t=12593 for supported versions. You still need to have a webserver installed to use it.
M3kk
Post Fri Jan 30, 2015 4:50 pm
Hi Swoop,
can u put back the "Add Path" button to the LIbrary / Shared Folders tab?
Thanks in advice.
