Microsoft IIS Smooth Streaming help
Darko
Post Thu Apr 10, 2014 11:05 am
Hi! I haven't find any already open thread on this, but I'm quite new to Serviio, so please excuse me If this topic has been discussed before. It seems I can't stream any video in Microsoft IIS Smooth Streaming format, Serviio won't recognize the url. It's something not implemented yet or maybe I've done something wrong?
I use Serviio on a Mac, OS X Mavericks, Core 2 Duo with 4GB Ram. Transcoding is enabled, but I'm using a set-top-box which is not included in the profile list. However, it works fine with every profile listed. I'd like to stream Microsoft IIS Smooth Streaming to my set-top-box, because using Silverlight on a browser window makes my Mac run really hot (95 C!).
I've found that every IIS streams is basically an HTTP address with an XML file (ie: http://www.sitename.com/directory/name.islm/manifest), which defines the video quality and the portions of the video to be played in a defined time. But I can't go any further, my knowledge stops here.
Thank you in advance for your help!
(and excuse me: my english is not very trained!)
Post Fri Apr 11, 2014 7:43 pm
Re: Microsoft IIS Smooth Streaming help
It's not supported.
Can you post ffmpeg -i of the stream url?
Darko
Post Fri Apr 11, 2014 11:10 pm
:roll: ehn, I don't know where to start (sorry!)
EDIT: i tried. I don't know if I did it right.
"http://se-mi1-6.se.mediasetsmtlive.alice.cdn.interbusiness.it/CH13.isml/manifest: Invalid data found when processing input"
(this is the italian big brother live feed, it's the only one I know right now which is 24/7. But feel free to use another url, I have the same problem with every Smooth Streaming feed)
