Serviio and samsung tablet
tom81
Post Sun Apr 13, 2014 9:31 am
I tray connect my Samsung Galaxy tab 3 (DLNA certified) with my pc with Serviio but i don't understend what profile i do set for tablet
help me please
p.s.
with allshare it tray so the problem is serviio
AndrewW
Post Sun Apr 13, 2014 2:25 pm
Re: Serviio and samsung tablet
Just try to use the free Serviio Go app its much easier.
The web interface with serviio pro does not work with Android, as it relies on flash technology for android which is not supported past 4.1 ( IIRC)
tom81
Post Mon Apr 14, 2014 2:36 pm
ok i tray and say you response
tom81
Post Sat Apr 19, 2014 11:38 am
but it isn't free need serviio pro :oops: :roll:
NX3
Post Mon Apr 21, 2014 7:46 pm
Download Vlc from Google play, enabled hardware acceleration. Use ServiioGo and choose original. No flash needed. Vlc plays everything. No transcoding required.
Sent from my HTC One mini using Tapatalk
NX3
Post Mon Apr 21, 2014 7:47 pm
You can side load flash if you really want it, check.out xda forums
NX3
Post Mon Apr 21, 2014 7:49 pm
And use generic profile with Vlc
Users browsing this forum: Google [Bot] and 17 guests
