Remove MediaBrowser Password
carlton681ao
Post Sun Apr 20, 2014 4:59 pm
I am using the free version of Serviio. I set a password to check out the MediaBrowser. As I don't need that feature I tried to remove the password (and therefore disable the MediaBrowser) but that wasn't possible. I could set a different password but not remove it.
Is there a way to remove the password from the MediaBrowser or disable it?
Btw, the trial period is over so I can't change the password anymore.
Anyone knows how to help me?
carlton
Post Tue Apr 22, 2014 8:30 am
Re: Remove MediaBrowser Password
If the trial period is over, you don't have access to MediaBrowser anyway.
Return to General discussion
