[SOLVED] XBR 850a Compatibility
snowflake7
Post Wed Apr 23, 2014 5:44 pm
Just purchased XBR55X850A. Was thinking that I would swap out my WDLive for the media server feature built into the set. When I attempt to play MKV files created with MakeMKV the Television lists the files but selecting Play sends the TV in to a never ending loading loop. Screen is black with bars scrolling in the top right corner. Only way out of the loop is to power down and then unplug the TV. I am using the base 2013 profile.
MP4s play fine.
Do I need to tweak the profile?
Post Wed Apr 23, 2014 6:06 pm
Re: XBR 850a Compatibility
Could you provide format supported by your device ? see my signature links
I found this codec list supported
Could you provide information about your mkv file ?
snowflake7
Post Wed Apr 23, 2014 6:38 pm
Appreciate the quick reply. Will get the info this evening. I am assuming the MKV inrfo you need is per the Wiki link in your signature. Is the MediaInfo enough or do you need the ffmpeg output. The files are on a Synology NAS not sure how to run the script as I am new to Linux.
Post Wed Apr 23, 2014 6:57 pm
MediaInfo tool result could be fine.
snowflake7
Post Wed Apr 23, 2014 7:36 pm
Not sure about formats supported best I could find quick look. ffmpeg and MediaInfo for a video is attached.
vid01MediaInfo.txt
(4.45 KiB) Downloaded 806 times
vid01.txt
(7.73 KiB) Downloaded 789 times
Formats.txt
(880 Bytes) Downloaded 777 times
Post Thu Apr 24, 2014 6:39 am
Do you enable subtitle features on serviio console ?
Could you enable detailed logging and check the ffmpeg command line used during transcoding (or file was delivered in native format) ?
You can also try to remux your file in a new mkv container, not sure MakeMKV is the best for Sony Bravia.
Something like this : ffmpeg -i Input.mkv -map 0 -c copy Output.mkv
or try the Serviio WinHelper tool (Remux tab : remux in same container type)
snowflake7
Post Thu Apr 24, 2014 3:24 pm
Media is being delivered in its native form. No transcoding. Just for fun I turned on transcoding and got the same result.
Subtitles are disabled in the console.
Will attempt to remux a file, but I won't be able to get to that until this evening.
Post Thu Apr 24, 2014 3:46 pm
snowflake7 wrote:Media is being delivered in its native form. No transcoding.
Ok, so there is probably something in file that Sony Bravia player does not like (suspect mkv container).
snowflake7 wrote:Will attempt to remux a file, but I won't be able to get to that until this evening.
OK
snowflake7
Post Fri Apr 25, 2014 1:34 pm
Remuxed a couple of titles. XBR850 successfully plays them both. Obviously something that it didn't like in the container. I use MakeMkv exclusively for BluRay rips. Are you aware of any settings that I would change in MakeMKV and avoid having to remuxing the file.
Post Fri Apr 25, 2014 4:30 pm
I did not use MakeMKV, so I could not help your for settings. But you can remux your file with ffmpeg after BR ripping.
Users browsing this forum: Google [Bot] and 36 guests
