F6400 literally vanished from Serviio.
Mozts
Post Fri Apr 25, 2014 1:48 am
Hi, out of nowhere, my Samsung UN46F6400 doesn't appear anymore on my Serviio "Status" bar no matter how many times I refresh it, nor does Serviio input option shows up on the TV.
The TV is connected wirelessly to a Windows 8.1, running Serviio 1.4.1.2 and Java 7 Update 55. Everything was working fine and then it wasn't. I tried reconnecting the WiFi, rebooted my PC, toyed around with Serviio network options, I even tried to force an IP via TV Network menu but to no result. The weird thing is, I have a second TV, 60F6400 on the same network and its still working fine(although it is connected by cable). Network-able apps like Netflix and YouTube also work fine on the TV.
If anyone has an idea what could be the issue, I would love to hear it. Thanks in advance.
Iveky
Post Fri Apr 25, 2014 4:25 am
Re: F6400 literally vanished from Serviio.
disable firewall on pc?
Mozts
Post Fri Apr 25, 2014 4:24 pm
Iveky wrote:disable firewall on pc?
There is no firewall to disable.
Post Mon Apr 28, 2014 7:39 pm
Might be the Windows Home network settings - don't remember the exact name of the feature, but you have to enable devices on your network to see each other.
