Streaming flac files upto 24/196 without downsampling?
dikkiedirk
Post Sat Apr 26, 2014 9:56 pm
I just installed Serviio on my server to stream my audio(flac) files upto 24 bit 192 kHz to my Network Audio Player.
I haven't set any profile, it is at the default Generic DLNA profile.
Are the files streamed to the player without any downsampling?
Or do I need to create a profile to avoid downsampling?
probedb
Post Mon Apr 28, 2014 9:54 am
Re: Streaming flac files upto 24/196 without downsampling?
What format does your network audio player say it's receiving?
If it says anything other than what you're expecting then I would raise an issue, not before.
Post Mon Apr 28, 2014 11:12 am
The Generic DLNA profile does not transcode audio files for media in your Local Library. Hence all audio files are played natively without downsampling.
Audio from Online source however is transcoded to MP3 format, 384k bit rate for audio containers: FLV, ASF, RTP, RTSP, MP3, MP4.
probedb
Post Thu May 01, 2014 1:58 pm
DenyAll wrote:The Generic DLNA profile does not transcode audio files for media in your Local Library. Hence all audio files are played natively without downsampling.
Do you mean 320kbps? Although you can go higher for MP3 it's not part of the standard.
Post Sat May 03, 2014 12:29 am
Nope, double checked - the Generic DLNA profile transcodes to MP3, 384 kbps. Why it is so would be something to ask zip.
Remember though this only for online sources. Local sources are not transcoded by this profile.
Users browsing this forum: No registered users and 80 guests
