H.264, SD resolution live streams problem
mackowiakp
Post Fri May 02, 2014 9:38 am
I wrote about problem in different topic as a part of other issues. But - i think - it should be separate topic.
I use my satbox as live streams source. There is several channels encoded as H.264 but resolution in SD, not HD.
Such streams are not recognised by Serviio server as working source, test provided via Serviio console fails.
But the same streams are fully streamable via satbox build-in WEB interface to any Web browser.
Is any possibility to make it working? I am not expert in transcoding, so my question.
[EDIT]
LOGS
[maciek@piotr ~]$ ffmpeg -i http://pvr:8001/1:0:1:4288:2BC0:13E:820000:0:0:0
ffmpeg version 2.0.3 Copyright (c) 2000-2013 the FFmpeg developers
  built on Feb  9 2014 23:12:38 with gcc 4.8.2 (GCC)
  configuration: --prefix=/usr --enable-shared --libdir=/usr/lib64 --shlibdir=/usr/lib64 --incdir=/usr/include --disable-stripping --enable-postproc --enable-gpl --enable-pthreads --enable-libtheora --enable-libvorbis --disable-encoder=vorbis --enable-libvpx --enable-x11grab --enable-runtime-cpudetect --enable-libdc1394 --enable-libschroedinger --enable-librtmp --enable-libspeex --enable-libfreetype --enable-libnut --enable-libgsm --enable-libcelt --enable-libopus --disable-libopencv --enable-libopenjpeg --enable-libtwolame --enable-libxavs --enable-frei0r --enable-libmodplug --enable-libass --enable-gnutls --enable-libcdio --enable-libpulse --enable-libv4l2 --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-version3 --enable-libx264 --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libxvid
  libavutil      52. 38.100 / 52. 38.100
  libavcodec     55. 18.102 / 55. 18.102
  libavformat    55. 12.100 / 55. 12.100
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 79.101 /  3. 79.101
[NULL @ 0x134bf40] non-existing PPS referenced
[h264 @ 0x134bf40] non-existing PPS 0 referenced
[h264 @ 0x134bf40] decode_slice_header error
[h264 @ 0x134bf40] no frame!
[h264 @ 0x134bf40] non-existing PPS referenced
[h264 @ 0x134bf40] mmco: unref short failure
    Last message repeated 1 times
[h264 @ 0x134bf40] number of reference frames (0+4) exceeds max (3; probably corrupt input), discarding one
[mpegts @ 0x131fd20] Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 0x131fd20] Could not find codec parameters for stream 1 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16p): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 2 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 3 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 4 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 5 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 6 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 7 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 8 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 9 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 10 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 11 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 12 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 13 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 14 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 15 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 16 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 17 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 18 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 19 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 20 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 21 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 22 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 23 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 24 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 25 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 26 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 27 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 28 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 29 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 30 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 31 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 32 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 33 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 34 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 37 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 38 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 39 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 40 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 41 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 42 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 43 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 44 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 45 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 46 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 47 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 48 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 49 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 50 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 51 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 52 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 53 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 54 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 55 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 56 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 57 (Video: h264 ([27][0][0][0] / 0x001B)): unspecified size
[mpegts @ 0x131fd20] Could not find codec parameters for stream 58 (Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels): unspecified frame size
Input #0, mpegts, from 'http://pvr:8001/1:0:1:4288:2BC0:13E:820000:0:0:0':
  Duration: N/A, start: 36128.567067, bitrate: 192 kb/s
  Program 17001
    Stream #0:41[0x101]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:42[0x201]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17002
    Stream #0:43[0x102]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:44[0x202]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17003
    Stream #0:45[0x103]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:46[0x203]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17004
    Stream #0:47[0x104]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:48[0x204]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17005
    Stream #0:49[0x105]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:50[0x205]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17006
    Stream #0:51[0x106]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:52[0x206]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17007
    Stream #0:53[0x107]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:54[0x207]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17008
    Stream #0:55[0x108]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:56[0x208]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17009
    Stream #0:57[0x109]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:58[0x209]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17010
    Stream #0:0[0x110]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn, 180k tbc
    Stream #0:1[0x210]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels, s16p
  Program 17011
    Stream #0:2[0x111]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:3[0x211]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17012
    Stream #0:4[0x112]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:5[0x212]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17013
    Stream #0:6[0x113]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:7[0x213]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17014
    Stream #0:8[0x114]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:9[0x214]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17015
    Stream #0:10[0x115]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:11[0x215]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17016
    Stream #0:12[0x116]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:13[0x216]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17017
    Stream #0:14[0x117]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:15[0x217]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17018
    Stream #0:16[0x118]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:17[0x218]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17019
    Stream #0:18[0x119]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:19[0x219]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17020
    Stream #0:20[0x100]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:21[0x200]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17021
  Program 17022
  Program 17023
    Stream #0:22[0x123]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:23[0x223]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17024
    Stream #0:24[0x124]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:25[0x224]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17025
  Program 17026
    Stream #0:26[0x126]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:27[0x226](pol): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
    Stream #0:28[0x326](eng): Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17027
    Stream #0:29[0x127]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:30[0x227]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17028
    Stream #0:31[0x128]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:32[0x228]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17029
    Stream #0:33[0x129]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:34[0x229]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17030
  Program 17031
  Program 17032
    Stream #0:35[0x132]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 720x576 [SAR 16:11 DAR 20:11], 25 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0:36[0x232]: Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s
  Program 17033
    Stream #0:37[0x133]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:38[0x233]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
  Program 17034
    Stream #0:39[0x134]: Video: h264 ([27][0][0][0] / 0x001B), 90k tbr, 90k tbn
    Stream #0:40[0x234]: Audio: mp3 ([4][0][0][0] / 0x0004), 0 channels
Post Fri May 16, 2014 11:37 am
Re: H.264, SD resolution live streams problem
Sorry for the delay. FFmpeg doesn't output (and recognize) the streams parameters, like resolution of the video stream, number of channels of the audio. that's why Serviio rejects it.
You could try a newer FFmpeg version, different output stream parameters (if you can change them), or raise a ticket with FFmpeg to implement support for streams like yours.
mackowiakp
Post Sat May 17, 2014 6:01 am
Hmmm. But I can stream such stream to VLC without problems. VLC is based on ffmpeg libraries so I think it is possible to stream it to Serviio. Dont You think so?
Post Sat May 17, 2014 10:12 am
It might be, but Serviio requires those parameters for each file / stream to work. Those values are integral part of Serviio's delivery system.
Return to General discussion
