peer-stream
Lupin
Post Fri May 02, 2014 3:48 pm
peer-stream
Hello!
I'm Lupin! :)
I'M a great user of serviio, and it's the easierst way to stream stuff...well if you know how to
Is anybody familiar with peer-stream? Hmm yes it's a nother stream page. but a big one. Coz i found many streams running there.
it's similar to the other of course.
So, this it not a clear request, if the API of peer-stream is the same to one of the already existing plugins.
But has anybody run that on the TV? and with what plugin?
If not, is it possible to get a plugin for peer-stream?
would be great!
thnx!
Lupin
Iveky
Post Sat May 03, 2014 11:19 am
Re: peer-stream
any example link to peer streams?
Lupin
Post Tue May 06, 2014 12:45 pm
Re: peer-stream
Hi
I have a german link
http://peer-stream.com/api/embedplayer/?id=euronews&e=1
can't find any index of available streams.
But the stream looks like this.
Return to Plugin requests
