Serviio e file mkv
vinny74
Post Sun May 04, 2014 6:07 pm
Serviio e file mkv
Hello everyone I have the problem that Serviio does not recognize the file. "Mkv" this is the log I get
" 2014-05-04 20:03:25,592 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/archivio/multimedia/video/Batman.1989.mkv). Message: Unknown video codec.
2014-05-04 20:03:25,739 WARN [LibraryManager] Skipping processing metadata for an unsupported file (/archivio/multimedia/video/Star.Trek.2009.mkv). Message: UnKnown video codec. "
This is an on-line translation
Post Sun May 04, 2014 10:15 pm
Re: Serviio e file mkv
Please post MediaInfo details for the file - see viewtopic.php?f=5&t=4510
vinny74
Post Mon May 05, 2014 5:15 am
DenyAll wrote:Please post MediaInfo details for the file - see viewtopic.php?f=5&t=4510
Generale
ID univoco : 193542890031296082252959124429371608835 (0x919B0136DDEAC455BA5E459111C80F03)
Nome completo : \\gateway\Archivio Multimediale\video\Star.Trek.2009.mkv
Formato : Matroska
Versione formato : Version 4 / Version 2
Dimensione : 2,84 GiB
Durata : 2o 6min
Bitrate totale : 3.214 Kbps
Data codifica : UTC 2014-04-12 22:02:16
Creato con : mkvmerge v6.8.0 ('Theme for Great Cities') 32bit built on Mar 2 2014 21:27:07
Compressore : Lavf54.63.104
Formato : HEVC
Formato/Informazioni : High Efficiency Video Coding
Profilo formato : Main@L4.0
ID codec : V_MPEGH/ISO/HEVC
Durata : 2o 6min
Bitrate : 2.254 Kbps
Larghezza : 1.920 pixel
Altezza : 800 pixel
Rapporto aspetto visualizzazione : 2,40:1
Modalità frame rate : Costante
Frame rate : 23,976 fps
Spazio colore : YUV
Croma subsampling : 4:2:0
Profondità bit : 8 bit
Bit/(pixel*frame) : 0.061
Dimensione della traccia : 2,00 GiB (70%)
Default : Si
Forced : No
Audio #1
Formato : AC-3
Formato/Informazioni : Audio Coding 3
Estensione modo : CM (complete main)
Impostazioni formato, Endianness : Big
ID codec : A_AC3
Durata : 2o 6min
Modalità bitrate : Costante
Bitrate : 448 Kbps
Canali : 6 canali
Posizione canali : Front: L C R, Side: L R, LFE
Frequenza campionamento : 48,0 KHz
Profondità bit : 16 bit
Modo compressione : Con perdita
Ritardo video : 5ms
Dimensione della traccia : 406MiB (14%)
Lingua : Italiano
Default : Si
Forced : No
Audio #2
Formato : AC-3
ID codec : A_AC3
Durata : 2o 6min
Bitrate : 448 Kbps
Canali : 6 canali
Ritardo video : 5ms
Lingua : Inglese
Default : No
Forced : No
Testo #1
Formato : UTF-8
ID codec : S_TEXT/UTF8
ID codec/Informazioni : UTF-8 Plain Text
Lingua : Italiano
Default : No
Forced : No
Testo #2
Formato : UTF-8
Lingua : Inglese
Default : No
Forced : No
Post Mon May 05, 2014 10:12 am
HEVC (h265) is not yet supported by Serviio, but is on the development list - see https://bitbucket.org/xnejp03/serviio/i ... e-matching. No time frames as yet.
vinny74
Post Mon May 05, 2014 4:49 pm
Ok thanks
Users browsing this forum: Baidu [Spider], Google [Bot] and 34 guests
