Fetch TV box Encoding MKV
goodthanks15
Post Wed May 14, 2014 9:32 am
Currently working on a profile for a Fetch TV box. Shown Here -
http://www.fetchtv.com.au/
Dont have any issues playing files through it but I do have an issue with MKV's with subtitles. Their is no way to stop the fetch box displaying any subtitle streams. So my plan is to encode MKV to TS files.
Here is the profile so far.
<Profile id="Fetch" name="Fetch TV Gen 2" extendsProfileId="1">
      <Detection>
                        <HttpHeaders>
            <User-Agent>.*Linux/2.6.37-3.2-svn1472.*</User-Agent>
         </HttpHeaders>
      </Detection>
The box is a DLNA server and renderer but the renderer doesnt respond to UPnP requests so I had to use User-Agent for detection. Not sure how practical that is but the box is detected so it works.
The encoding doesn't work. Without the profile when I highlight files on the fetch box it displays media info for the file. When im using the profile any MKV files do not display any media info and wont play. The temp file (.stf) isnt even created in c:\windows\temp\serviio
If I transcode an MKV manually using the following command line
ffmpeg -i "test.mkv" -y -async 1 -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts "test.ts"
I can select the TS file on the fetch box and it displays the media info and plays fine.
So it's just a problem with the box getting file information for MKV's that will be transcoded.
Anyone got any ideas?
Also is there a better way to remove the subtitle stream from MKV's without trancoding to TS?
Post Wed May 14, 2014 10:26 am
Re: Fetch TV box Encoding MKV
goodthanks15 wrote:...
On DLNA specification, file streamed in native format and file streamed with transcoding use different DLNA header information.
Serviio is DLNA compliant so use these header.
I suspect that your device does not support streams with transcoding flag enabled.
DLNA.ORG_PN= media profile
DLNA.ORG_OP=ab a-server supports TimeSeekRange, b-server supports RANGE
DLNA.ORG_PS= supported play speeds
DLNA.ORG_CI= 1- media is transcoded
DLNA.ORG_FLAGS= binary flags with device parameters
goodthanks15
Post Wed May 14, 2014 11:02 pm
I ran a few more tests and I think you are correct. Don't suppose there is any kind of work around for that?
Users browsing this forum: Baidu [Spider] and 54 guests
