MP3 via Mediabrowser restarts after 4 seconds on first play.
marko weber
Post Wed May 14, 2014 10:45 am
when i choose an mp3 to play via the Mediabrowser, the selected mp3 starts to play.
After 4 seconds ( tested multiple times ) the mp3 restarts playing from beginning and the plays fine till the end.
This only happens with mp3´s in a playlist.
Manually chosen and started mp3 plays fine without the restart after 4 seconds.
Is this a bug ?
marko
Post Thu May 15, 2014 6:20 pm
Re: MP3 via Mediabrowser restarts after 4 seconds on first p
Is it all mp3s you have or only some?
marko weber
Post Thu Dec 11, 2014 11:14 am
on most mp3's on server.
the weird thing is, sometimes all is fine
any tipps?
actionsoft
Post Thu Dec 18, 2014 2:50 pm
Hi all, this happens too to me. The problem isn't with the 4 seconds, the restart happens when the song finish to buffer. This happens with some low bitrate MP3s, 160 or lower I think. With FLAC and 320 MP3s works fine.
This is a client side problem with MediaBrowser, because this was happening too in ServiiGo (Android) and in latest versions was fixed...
Thank you for your attention :)
Post Thu Dec 18, 2014 3:56 pm
actionsoft
Post Thu Dec 18, 2014 8:23 pm
Great! and this can be changed in 1.4.1 or need to wait to 1.5? :P I don't find where change this!! xD
Post Fri Dec 19, 2014 11:27 am
1.5, it should be released pretty soon
actionsoft
Post Fri Dec 19, 2014 8:02 pm
Thank you for your quickly answers!! :P
