Where can I find serviio 1.4 download?
fonzeeee
Post Wed May 21, 2014 6:53 am
Where can I find version 1.4 download?
Im having issues with the new version and wish to downgrade as no one has responded to my post from other day in the Samsung section.
Ive searched everywhere and cannot find serviio 1.4 , used that version with no problems for a while.(been using serviio since 1.2 i think)
The current version is unusable for me as it require me to replug my whole network to get it to sync after playing each file.
I guess if theres no downgrade I will have to look elsewhere for my network streaming.
Post Wed May 21, 2014 1:25 pm
Re: Where can I find serviio 1.4 download?
I suspect that nobody has responded because generally they expect that you should search for a solution prior to posting. This saves people having to answer the question over and over.
Searching the forum:
viewtopic.php?f=5&t=12143&p=76139&hilit=+Versions+previous#p76139
viewtopic.php?f=6&t=12536#p76543
Or using Google:
http://www.videohelp.com/tools/Serviio/old-versions
http://www.digital-digest.com/software/ ... tory.html#
Having said that, I am not aware of any changes since 1.4 that would impact in the manner you are experiencing. Perhaps a detailed log may shed light on the underlying problem.
fonzeeee
Post Wed May 21, 2014 5:29 pm
Yay you found them! Thanks for providing the links I did try googling "serviio 1.4" and also forum search but couldnt find any.
I just read about the DEBUG thing to get a log file and thought do that before downgrading, however now it works perfectly again. (confused now)
The other night that I updated, I restarted my pc a few times even router etc. Still had the problem over several hours and 6-7 files. Even had the same thing the day after. Have no clue why it works flawlessly now.
Im very happy its all working smoothing now, syncs up in a few seconds everytime (much better then the samsung allshare), sorry about posting with the issue I had. It seems to have disappeared completely
Also many thanks for providing serviio, I find it very useful for watching stuff on TV.
I see your also from Adelaide lol small world :P
