Problem with a lot of mkv files!
Hi, I'm from Spain and I do not speak English very well.
I have several problems with mkv files.
I have Synology NAS with Serviio v1.4.1.2-0026
This is the info of ffmpeg in one file (Juego de Tronos T04E03 Rompedora de Cadenas [720p HDTV DUAL SUBS] [HDTeam].mkv):
And this is the log of serviio.log:
Logically, the file is not added to the library
Any tips?
thanks
- Code:
ffmpeg version 2.1-compiled_by_patters_for_Serviio Copyright (c) 2000-2013 the FFmpeg developers
built on Nov 5 2013 13:59:17 with gcc 4.2.3 (GCC)
configuration: --arch=arm --cpu=armv5te --prefix=/opt --extra-cflags=-I/tmp/include --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-vfp --disable-neon --disable-debug --enable-pthreads --enable-libshine --enable-librtmp --enable-libass --enable-libx264 --enable-gpl --extra-version=compiled_by_patters_for_Serviio
libavutil 52. 48.100 / 52. 48.100
libavcodec 55. 39.100 / 55. 39.100
libavformat 55. 19.104 / 55. 19.104
libavdevice 55. 5.100 / 55. 5.100
libavfilter 3. 90.100 / 3. 90.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
[matroska,webm @ 0x48e40] Stream #3: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #4: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #5: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #6: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #7: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #8: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #9: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #10: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #11: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #12: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #13: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #14: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #15: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #16: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #17: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #18: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #19: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #20: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #21: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #22: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #23: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Stream #24: not enough frames to estimate rate; consider increasing probesize
[matroska,webm @ 0x48e40] Could not find codec parameters for stream 15 (Attachment: none): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, matroska,webm, from '/volume1/Series/Game of Thrones/T4 HD/Juego de Tronos T04E03 Rompedora de Cadenas [720p HDTV DUAL SUBS] [HDTeam].mkv':
title : Game of Thrones S04E03 (2014) - Breaker of Chains
creation_time : 2014-05-01 02:41:28
Duration: 00:57:42.47, start: 0.000000, bitrate: 5563 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x716 [SAR 1:1 DAR 320:179], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : T4 E03 Rompedora de Cadenas DON HDTeam
Stream #0:1(spa): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) (forced)
title : Castellano AC3 384 kbps 5.1
Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s
title : Inglés AC3 384 kbps 5.1
Stream #0:3(spa): Subtitle: ssa (default) (forced)
title : Forzados estilos
Stream #0:4(spa): Subtitle: subrip
title : Forzados planos
Stream #0:5(spa): Subtitle: ssa
title : Completos estilos
Stream #0:6(spa): Subtitle: subrip
title : Completos planos
Stream #0:7(eng): Subtitle: ssa
title : Inglés estilos
Stream #0:8(eng): Subtitle: subrip
title : Inglés planos
Stream #0:9(eng): Subtitle: subrip
title : Inglés para sordos planos
Codec 0x4f5446 is not in the full list.
Stream #0:10: Attachment: unknown_codec
filename : BOOTERZZ.ttf
mimetype : application/vnd.ms-opentype
Codec 0x18000 is not in the full list.
Stream #0:11: Attachment: unknown_codec
filename : Cardinal-Alternate.ttf
mimetype : application/x-truetype-font
Stream #0:12: Attachment: unknown_codec
filename : Cardinal.ttf
Stream #0:13: Attachment: unknown_codec
filename : PyriformTonesNF.ttf
Stream #0:14: Attachment: unknown_codec
filename : Terminal.ttf
Stream #0:15: Attachment: none
filename : Trajan Pro.ttf
mimetype : application/x-dosexec
Stream #0:16: Attachment: unknown_codec
filename : Yataghan.ttf
Stream #0:17: Attachment: unknown_codec
filename : Logo Juego de tronos.ttf
Stream #0:18: Attachment: unknown_codec
Stream #0:19: Attachment: unknown_codec
Stream #0:20: Attachment: unknown_codec
Stream #0:21: Attachment: unknown_codec
Stream #0:22: Attachment: unknown_codec
Stream #0:23: Attachment: unknown_codec
Stream #0:24: Attachment: unknown_codec
Any tips?
thanks
