Sony KDL-55W805A with PKG4.401EUA won't play some AVC*
bik
Post Sun Apr 06, 2014 12:24 pm
Hi guys,
Does someone experienced issues playing MPEG-TS File AVC Encoded on Sony Bravia ?
It seems some files are reproduced and some others not, even having the same encoding method.
Actual configuration is :
Sony KDL-55W805A (V-Physical-Unit-Info: pa="BRAVIA KDL-55W805A";,X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-55W805A"; mv="1.7";)
Sony Firmware PKG4.401EUA (latest)
Profile 'Sony Bravia TV (2013)
Serviio on Ubuntu Server 3.11.0-18-generic
ffmpeg version 2.2.git Copyright (c) 2000-2014 the FFmpeg developers built from latest source
Working Item log/mediainfo:
2014-04-06 14:17:23,766 DEBUG [VideoDeliveryEngine] Delivering item '1695' for client 'Identifier=192.168.12.101, Profile=Sony Bravia TV (2013)'
2014-04-06 14:17:23,766 DEBUG [VideoDeliveryEngine] Delivering file 'Django unchained .ts' in native format
2014-04-06 14:17:23,766 DEBUG [MediaItemDAOImpl] Getting file of media item 1695
2014-04-06 14:17:23,767 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1695) as read
2014-04-06 14:17:23,788 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-04-06 14:17:23,788 DEBUG [GETMethodProcessor] Stream entity has length: 13242169440
2014-04-06 14:17:23,788 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 13242169440,Date: Sun, 06 Apr 2014 12:17:23 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 160776192-13402945631/13402945632,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,rea
Complete name                            : ./Django unchained .ts
Format                                   : MPEG-TS
File size                                : 12.5 GiB
Duration                                 : 2h 38mn
Overall bit rate                         : 11.2 Mbps
Menu ID                                  : 7776 (0x1E60)
Format profile                           : Main@L4.0
Codec ID                                 : 27
Duration                                 : 2h 38mn
Bit rate                                 : 10.3 Mbps
Height                                   : 1 080 pixels
Frame rate                               : 25.000 fps
Scan type                                : MBAFF
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.199
Stream size                              : 11.4 GiB (92%)
Encryption                               : Encrypted
Non working Item log/mediainfo:
2014-04-06 14:19:06,357 DEBUG [VideoDeliveryEngine] Delivering item '1679' for client 'Identifier=192.168.12.101, Profile=Sony Bravia TV (2013)'
2014-04-06 14:19:06,357 DEBUG [VideoDeliveryEngine] Delivering file 'Duma .ts' in native format
2014-04-06 14:19:06,357 DEBUG [MediaItemDAOImpl] Getting file of media item 1679
2014-04-06 14:19:06,358 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1679) as read
2014-04-06 14:19:06,381 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-04-06 14:19:06,381 DEBUG [GETMethodProcessor] Stream entity has length: 4254475812
2014-04-06 14:19:06,382 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Length: 4254475812,Date: Sun, 06 Apr 2014 12:19:06 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 1943052288-6197528099/6197528100,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2014-04-06 14:19:22,372 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2014-04-06 14:19:22,372 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Complete name                            : ./Duma .ts
Format                                   : MPEG-TS
File size                                : 5.77 GiB
Duration                                 : 1h 44mn
Overall bit rate                         : 7 870 Kbps
Menu ID                                  : 7255 (0x1C57)
Codec ID                                 : 27
Duration                                 : 1h 44mn
Bit rate                                 : 7 093 Kbps
Scan type                                : MBAFF
Bits/(Pixel*Frame)                       : 0.137
Stream size                              : 5.20 GiB (90%)
Post Sun Apr 06, 2014 6:23 pm
Re: Sony KDL-55W805A with PKG4.401EUA won't play some AVC*
bik wrote:...It seems some files are reproduced and some others not, even having the same encoding method.
Are you sure there having the same encoding method?
Both are encrypted...what is this encryption ?
bik
Post Sun Apr 06, 2014 6:33 pm
No clues from mediainfo output, but Serviio is able to extract thumbnails for both
bik
Post Tue Apr 08, 2014 3:45 pm
Could it be a workaround enforcing transcoding for any Avc.?
How Can it be performed?
bik
Post Fri May 23, 2014 8:36 pm
I found a workaround transcodind into mkv
Using ffmpeg
echo    ffmpeg -i "$INFILE"  --> "$OUTFILE"
        ffmpeg -y  -fflags genpts -i "$INFILE" -acodec copy -vcodec copy -f matr
matroska -sn "$OUTFILE"
Does Will be better in seamless Way?
Post Sat May 24, 2014 7:16 am
So problem comes from mpegts container.
You can also try to remux to mpegts with same command line.
bik
Post Wed Jun 18, 2014 9:01 pm
Actually I'm using Sony standard profile,
could you please help me updating XML to remux MPEGTS to MKV ?
