SOPCAST VIDEO WEB RESOURCE
Gapito
Post Fri May 16, 2014 3:45 pm
Re: SOPCAST VIDEO WEB RESOURCE
Hello. First of all, I must say thank you for your work.
I have a Samsung BD-F6500 (blu-ray player with Smart TV). Well, but the problem here is that the sopcast streaming cuts off a few minutes after it starts. Usually, it works fine during 2 minutes, but then my BD displays a message: "Check your net connection". Before you say anything about my net connection, this is through wifi, but except the sopcast streaming, everything works fine: direct streaming, and other platforms like Plex... So, I don't think is a net problem.
Yesterday, I checked again, and I disabled de "Transcode" option in the Serviio-Console. It looked like it solved the problem, because this time the streaming lasted 8 or 9 minutes! :D But suddenly, again the message: "check your net connection" :cry:
I have tryed including the new line to the profile user, but no success.
Then, I turned on again the "Transcode" option... Other 10 minutes of streaming, happy again... but bad news at last: "Check your net connection" :?
During the streaming, pressing the "info" button on my BD player, it shows some data, including the source, and always is the Sopcast#1 source, it never jumps to other item.
Any idea about this? :roll:
gabrielra
Post Tue May 27, 2014 1:04 am
First, sorry for my bad english, i'm French / Portuguese
I think i have one solution for "Sopcast Stream" for Samsung TV. For me, with Samsung TV Serie F, after many hours and combination, it's OK.
MY CONFIG :
- Servio 1.4.1.2 (works on 1.3.1 too)
- Samsung TV Serie F
TEST :
- With this Sopcast Plugin :
* Without modif profile, without transcode : K-O - Disconnected each 5/10 minutes (Sopcast #1 to #2, ect... )
* Without modif profile, with transcode : K-O - Disconnected each 5/10 minutes (Sopcast #1 to #2, ect... )
* With modif profile (first post) , without transcode : K-O - Disconnected each 5/10 minutes (Sopcast #1 to #2, ect... )
* With modif profile (first post), with transcode : K-O - Disconnected each 5/10 minutes (Sopcast #1 to #2, ect... )
- With the classic adress (192.168.*.*:8902)
So, I tried an alternative solution and IT'S WORKS without disconnects :
REQUIREMENT :
- VLC (an old version in my case because i have an old laptop and this version is great for my laptop for 720p movies/streams - 2.0.8 - but i think it's good with a most recent version)
- Sopcast
- Serviio
SETTINGS :
* In VLC :
- Tools -> Preferences (and active Advanced Parametre at botom) -> "Flux de Sortie" (i donk know the traduction in English VLC so, a pic :
Add
#duplicate{dst="http{mux=ts,dst=:8913}",dst=display}
( 8913 is my port, you can change if you want but i will use this port for my explaination)
and Save
* In Serviio :
- You can install my modified profile in attachment (it's 1.3.1 profile but works great on 1.4.1.2)
- Choose Samsung TV / Player (C/D/E/F-Series)
- Enable Transcode (i dont tried without transcode but now it's working so i will change anything)
- Add in "Library" -> "Online Source"
( 192.168.1.66 is the IP of my computer, change with your computer ip )
* In Sopcast :
- In "Options" (1 on the picture), choose VLC as External Player (2 on the picture)
- Start your stream and when is playing, start this video in VLC with the button under the video (3 on the picture)
After started the stream, go to Serviio on "Library" -> "Online Source" and Refresh the Link
You need to keep VLC open on your PC during the streaming
After +/- one minute, start the stream on your TV !
I hope it will be work for you. If you need more informations, i'm here.
profiles.xml
(101.98 KiB) Downloaded 1610 times
Post Tue May 27, 2014 11:42 pm
Very Clever! Use VLC to read the Sopcast stream and use the Advanced Option "Stream Output"
to send the stream to the Samsung TV, effectively buffering it and eliminating the glitches in the raw stream that the Samsung cannot handle. Well done!
Coronel
Post Wed Jun 04, 2014 11:38 pm
gabrielra wrote:Hello,
MY CONFIG :
TEST :
REQUIREMENT :
- Sopcast
- Serviio
SETTINGS :
* In VLC :
Add
and Save
* In Serviio :
* In Sopcast :
Good night gabrielra .
I use Serviio 1.4.1.2 Pro After seeing some tutorials , type vintilla and now I here :
viewtopic.php?f=20&t=7249&p=91710 # p91688
with the title : " SOPCAST ​​VIDEO WEB RESOURCE " I tried several times and still can not .
Excuse my ignorance , but I did it the way you told us .
VLC 2.0.6 :
1. open VLC
2 . Select Tools , Preferences
3 . Under Display Settings , select All ( lower left corner) . In other versions of
      VLC can be labeled Advanced)
4 . Select the output stream in the left pane .
5 . Add the following to the standard output stream chain:
# duplicate { dst = display , dst = " transcode { acodec = mpga , ab = 128 } : http { mux = ts , dst = : 8913 } " }
6 . Press Save .
7 . Select Media File Open and play any video file . This is important - the flow should
      be running for the next step .
SERVIIO PRO 1.4.1.2 :
1 . Serviio Console Open
2 . Choose Library , online sources and press Add
. 3 Enter the details as below , and press check flow URL :
 IP OF MY MACHINE , COMPUTER : 10.1.1.7
Then put http:// 10.1.1.7:8913 - http:// 10.1.1.7:8080 - http:// 10.1.1.7:8081 -
http:// 10.1.1.7:1234 , liberated at the firewall , I disabled firewall and anti -virus , but did not give Serviio ok when I click " Check Stream URL " . Only gave X have not found the IP .
Where am I wrong?
I do not want to see tv channels not just want to Stream using Serviio with VLC playing from computer to TV , only video files . But I did not install " SopCast 3.8.3 " as the end of your post .
Even though I do not want to see tv channels , so I can see the videos files that are on your computer , using the Serviio + VLC , I also need to install " SopCast 3.8.3 " ?
Thank you.
Bon gabrielra de nuit .
J'utilise Serviio 1.4.1.2 Pro Après avoir vu quelques tutoriels , le type vintilla et maintenant je ici :
avec le titre : " SOPCAST ​​VIDEO RESSOURCES WEB " J'ai essayé plusieurs fois et ne peuvent toujours pas .
Excusez mon ignorance, mais je l'ai fait la façon dont vous nous avez dit .
VLC 2.0.6 :
Une . Ouvrir VLC
2 . Sélectionnez Outils , Préférences
3 . Sous Paramètres d'affichage , sélectionnez Tout ( coin inférieur gauche ) . Dans d'autres versions de
      VLC peut être étiqueté avancée )
4 . Sélectionnez le flux de sortie dans le volet gauche .
5 . Ajouter le texte suivant à la chaîne de flux de sortie standard :
# Duplicate { dst = affichage , dst = " transcode { acodec = mpga , ab = 128 } : http { mux = ts , dst = : 8913 } "}
6 . Appuyez sur Enregistrer .
7 . Sélectionnez Fichier Open Media et jouer n'importe quel fichier vidéo . Ceci est important - le débit devrait
      être candidat à la prochaine étape .
Serviio PRO 1.4.1.2 :
1 . Serviio Ouvrir la console
2 . Choisissez bibliothèque, des sources en ligne et appuyez sur Ajouter
. 3 Entrez les détails ci-dessous et appuyez sur Vérifier flux URL :
 IP de ma machine , ORDINATEUR : 10.1.1.7
Puis mettre http:// 10.1.1.7:8913 - http:// 10.1.1.7:8080 - http:// 10.1.1.7:8081 -
http:// 10.1.1.7:1234 , libéré au pare-feu , je pare-feu désactivé et anti- virus , mais ne lui donne Serviio ok quand je clique sur " Vérifier URL de flux " . Seulement donné le X n'ont pas trouvé l'adresse IP .
Où suis-je tort ?
Je ne veux pas voir les chaînes de télévision ne veulent pas seulement à diffuser à l'aide Serviio avec VLC lecture à partir de l'ordinateur à la télévision , seuls les fichiers vidéo . Mais je n'ai pas installé " 3.8.3 SopCast " comme la fin de votre message .
Même si je ne veux pas voir les chaînes de télévision , donc je peux voir les fichiers vidéos qui sont sur votre ordinateur, en utilisant le Serviio + VLC , j'ai aussi besoin d'installer " SopCast 3.8.3 " ?
Merci.
Coronel
MY CONFIG :
TEST :
REQUIREMENT :
- Sopcast
- Serviio
SETTINGS :
* In VLC :
Add
and Save
* In Serviio :
* In Sopcast :
VLC 2.0.6 :
1. open VLC
6 . Press Save .
Where am I wrong?
Thank you.
VLC 2.0.6 :
Une . Ouvrir VLC
Où suis-je tort ?
Merci.
Coronel
MY CONFIG :
TEST :
REQUIREMENT :
- Sopcast
- Serviio
SETTINGS :
* In VLC :
Add
and Save
* In Serviio :
* In Sopcast :
VLC 2.0.6 :
1. open VLC
6 . Press Save .
Where am I wrong?
Thank you.
VLC 2.0.6 :
Une . Ouvrir VLC
Où suis-je tort ?
Merci.
Coronel
MY CONFIG :
TEST :
REQUIREMENT :
- Sopcast
- Serviio
SETTINGS :
* In VLC :
Add
and Save
* In Serviio :
* In Sopcast :
VLC 2.0.6 :
1. open VLC
6 . Press Save .
Where am I wrong?
Thank you.
VLC 2.0.6 :
Une . Ouvrir VLC
Où suis-je tort ?
Merci.
gabrielra
Post Fri Jun 06, 2014 11:38 pm
If you want only stream VLC to your TV,
On VlC, tools -> preferences -> output stream (advanced parameters), add " #duplicate{dst="http{mux=ts,dst=:8913}",dst=display} " (without " " )
Play the stream and keep VLC running
On Serviio -> library -> online source -> add
Choose LIVE STREAM on Source Type and add : xxx.xxx.xxx.xxx:8913
(xxx.xxx.xxx.xxx is the IP of your computer)
save/add
Then, right click on the new element of your library -> refresh
Wait 1 minute and the stream is on your TV
Edit : but if you just watch movies files from your computer, it's more easyer to add movies files on your library, without online source. it's more for live streaming
Coronel
Post Mon Jun 09, 2014 4:15 pm
gabrielra wrote:If you want only stream VLC to your TV,
save/add
Hi friend. Thanks for your attention and patience. I have not yet completed the walkthrough that you inform us.
Now I configured VLC + Serbian.
In VLC, I added the information:
"# Duplicate {dst =" http {mux = ts, dst =: 8913} ", dst = display}"
in: Tools -> Preferences -> Display Settings -> Detailed -> output stream.
Open a video file and let ...
In Serviio added the information in the "Online Sources" tab:
Source Type: Live Streaming
Feed URL: My IP: xx.x.x.x: 8913
Clicked: Check the URL and V appeared green. Signal that worked communication with the Serviio VLC.
Then I went in VLC:
View (View) -> Playlist (PlayList) -> Network (Local Network) -> Universal Plug'n'Play. Then appeared the Serviio + Folders and Sub Folders. So far as this Ventilla showed in the post.
But still unable to play the video file to this Smart Tv "Universal Plug'n'Play" option, where I see the Serviio appears with your folders I open any of them and I click on any video file, the video wheel , Normal appears in the VLC screen, but only on computer. But the Smart TV does not appear. Nothing happens.
 What is still missing, I could not understand?
Please can tell me now, starting from where I could get after the "Universal Plug'n'Play" part, which I can already see the Serviio + folders and files. What is the step so that I can play for the tv?
Salut l'ami. Merci pour votre attention et de patience. Je n'ai pas encore terminé la procédure pas à pas que vous nous informiez.
Maintenant j'ai configuré VLC + serbe.
Dans VLC, j'ai ajouté l'information:
"# Duplicate {dst =" http {mux = ts, dst =: 8913} ", dst = affichage}"
dans: Outils -> Préférences -> Paramètres d'affichage -> Détail -> flux de sortie.
Ouvrez un fichier vidéo et laisser ...
En Serviio ajouté les informations dans l'onglet "Sources en ligne":
Type de source: Live Streaming
RSS URL: Mon IP: xx.x.x.x: 8913
Cliqué: Vérifiez l'URL et V est apparu vert. Signal qui a travaillé communication avec le Serviio VLC.
Puis je suis allé dans VLC:
Voir (View) -> Playlist (liste de lecture) -> réseau (réseau local) -> Universal Plug & Play. Puis sont apparus les dossiers + Serviio et sous-dossiers. Pour autant que ce Ventilla montré dans le poste.
Mais toujours pas en mesure de jouer le fichier vidéo à cette option Smart TV "Universal Plug & Play", où je vois la Serviio apparaît avec vos dossiers j'ouvre un d'eux et je clique sur un fichier vidéo, la roue de vidéo , Normal apparaît sur l'écran VLC, mais seulement sur l'ordinateur. Mais la Smart TV n'apparaît pas. Rien ne se passe.
 Ce qui manque encore, je ne pouvais pas comprendre?
S'il vous plaît peut me dire maintenant, à partir de l'endroit où je pourrais obtenir après la partie "Universal Plug & Play", que je vois déjà les Serviio + dossiers et fichiers. Quelle est l'étape de sorte que je peux jouer à la télé?
Merci.
Coronel
Post Wed Jun 11, 2014 10:28 pm
save/add
DenyAll, good night. I suppose maybe you're already tired and finding myself a boring, excuse me please.
I understand and know that you did the tests and worked on a samsung smart tv, as you mentioned in your first post.
And my tv is a Philips Smart. We soon learn that the types and modes settings are different paths.
But ultimately end up in the same and we're talking the same language, for we are all talking about DLNA.
So do not worry and do not worry if my tv is a smart Philips, Samsung, Lg etc, etc..
Also already know that VLC 2.1.3 does not work those functions. So I went back to version 2.0.6 or 2.0.8, as you say in the tutorial. Also use the latest version of Serviio 1.4.1.2 Pro
What I need to know from you is:
In VLC, you just made: - settings: * In VLC: - Tools -> Preferences (active and advanced Parametre the botom) -> "Flux Sortie" (i donk know VLC traduction in English so a pic: Add.
# Duplicate {dst = "http {mux = ts, dst =: 8913}", dst = display}
(8913 is my port, you can change if you want, but I will use this port to my explanation)
and Save.
Or you was also at: -> Tools -> Preferences -> Detail -> Main Interfaces and checked the box: Web / http -> Lua interpreter etc.?
In Serviio, you just made: - Choose Samsung TV / player (C / D / E / F-Series) - Enable Transcode (I have not tried without transcoding, but now it's working so I'm going to change anything) - Add on "Library" -> "Source Online" (192.168.1.66 is the IP of my computer, change your ip to the computer) * On Sopcast: - In "Options" (1 in the picture), choose VLC as external player ( 2 in the image) - Get your flow and when it is playing, get this video in VLC with (3 pictured) button below the video Then I started running, go to Serviio in "Library" -> "Source Online" and update You need to keep the link open VLC on your PC while streaming After + / - one minute, then launch the stream on your TV.
Anyway, you made other changes to the settings of VLC and Serviio, or only those that you reported?
Modified or opened doors in Modem?
For the steps to configure VLC + Serviio tells you how I did it. The Serviio find VLC and VLC finds Serviio, as posted by Ventilla picture.
Just have not got it after all, play for the tv. Something else missing to configure, is in Serviio, either in VLC, is the Modem?
DenyAll, bonne nuit. Je suppose que peut-être vous êtes déjà fatigué et me trouver un ennuyeux, excusez-moi s'il vous plaît.
Je comprends et je sais que vous avez fait des tests et a travaillé sur une Smart TV de Samsung, comme vous l'avez mentionné dans votre premier message.
Et ma tv est une Philips intelligente. Nous apprenons bientôt que les types et les modes réglages sont des chemins différents.
Mais finalement se retrouver dans la même et nous parlons la même langue, car nous parlons tous DLNA.
Donc, ne vous inquiétez pas et ne vous inquiétez pas si mon téléviseur est un Philips intelligent, Samsung, LG etc, etc.
Aussi savons déjà que VLC 2.1.3 ne fonctionne pas ces fonctions. Je suis donc retourné à la version 2.0.6 ou 2.0.8, comme vous le dites dans le tutoriel. Également utiliser la dernière version de Serviio 1.4.1.2 Pro
Qu'est-ce que j'ai besoin de savoir de vous, c'est:
Dans VLC, vous venez de faire: - paramètres: * En VLC: - Outils -> Préférences (active avancée Parametre botom) -> "Flux sortie" (i donk savent VLC Traduction en anglais pour un pic: Add.
# Duplicate {dst = "http {mux = ts, dst =: 8913}", dst = affichage}
(8913 est mon port, vous pouvez changer si vous voulez, mais je vais utiliser ce port pour mon explication)
et Save.
Ou vous étiez également à: -> Outils -> Préférences -> Détail -> Interfaces principales et coché la case: Web / http -> interpréteur Lua etc?
En Serviio, vous venez de faire: - Choisissez Samsung TV / lecteur (C / D / E / F-Series) - Activer Transcode (je n'ai pas essayé sans transcodage, mais maintenant ça fonctionne donc je vais changer quoi que ce soit) - Ajouter sur "Bibliothèque" -> "Source en ligne" (192.168.1.66 est l'adresse IP de mon ordinateur, changer votre adresse IP de l'ordinateur) * Sur Sopcast: - Dans "Options" (1) dans l'image, choisissez VLC comme lecteur externe ( 2 dans l'image) - Obtenez votre flux et quand il joue, obtenir cette vidéo dans VLC avec le bouton (3 photo) en dessous de la vidéo, puis j'ai commencé à courir, aller à Serviio dans "Bibliothèque" -> "Source en ligne» et mise à jour Vous devez garder le lien ouvert VLC sur votre PC tandis que le streaming Après + / - une minute, puis lancer le flux sur votre téléviseur.
Quoi qu'il en soit, vous avez fait d'autres modifications aux paramètres de VLC et Serviio, ou seulement ceux que vous avez déclaré?
Modifié ou ouvert des portes dans Modem?
Pour les étapes pour configurer VLC + Serviio vous dit comment j'ai fait. Le Serviio trouver VLC et VLC trouve Serviio, telle que publiée par image Ventilla.
N'ont tout simplement pas eu, après tout, jouer pour la télévision. Quelque chose d'autre manque à configurer, est en Serviio, soit dans VLC, est le modem?
hal9000ht
Post Sun Aug 17, 2014 9:59 am
Thanks to all previous posts.
In order to play audio in a Sony Bravia 2013 I replaced the output stream to:
# duplicate { dst = display , dst = " transcode{vcodec=mp1v, vb=1024, acodec=mpga, ab=128} : http { mux = ts , dst = : 8913 } " }
astalavista_thes
Post Thu Aug 21, 2014 4:53 pm
I have a related problem. I stream the http://127.0.0.1:8902 address locally using the Serviio online resource tab. I can load it in my TV however there are glitches in the picture/sound. Sometime the playback is slow and then speeds up then slows down etc. Do you know how to fix that problem? I tried this plugin which works but the same glitches appear. The stream appears correctly in my Sopcast screen. Any ideas?
Post Thu Aug 21, 2014 7:25 pm
Perhaps your cpu is too slow to transcode the stream for the tv, or your network cannot handle the stream data rate. Post ffmpeg for the sopcast stream.
astalavista_thes
Post Fri Aug 22, 2014 5:46 am
I don't know how to do that. :(
EDIT: I found out how to do it. I will post the results when I am back home.
astalavista_thes
Post Sat Aug 23, 2014 9:57 am
jhb50 wrote:Perhaps your cpu is too slow to transcode the stream for the tv, or your network cannot handle the stream data rate. Post ffmpeg for the sopcast stream.
I think that the following is what you're asking for. Thanks for your help.
Input #0, mpegts, from 'http://127.0.0.1:8902':
  Duration: N/A, start: 67522.354356, bitrate: 128 kb/s
  Program 1
    Stream #0:0[0x44]: Audio: mp3 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16p, 128 kb/s
    Stream #0:1[0x45]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Post Sat Aug 23, 2014 2:30 pm
yes, that's a high res stream which will tax your resources. Most streams are 640x480 which 1/4 of the size.
astalavista_thes
Post Sat Aug 23, 2014 3:28 pm
jhb50 wrote:yes, that's a high res stream which will tax your resources. Most streams are 640x480 which 1/4 of the size.
Isn't there any way to buffer the stream and transmit with some delay?
Post Sat Aug 23, 2014 7:57 pm
It is buffered but seems local network is not fast enough to keep it filled. Try wired rather than wireless.
Wobblz
Post Thu Nov 06, 2014 7:09 pm
I've got a Sony W605B and Serviio (1.4.1.2). I've installed the .groovy file and followed all the instructions but there's nothing in the Sopcast folder, even after repeatedly refreshing the stream and restarting the whole server, even the tv. Previously tried to just add a Live Stream with http://127.0.0.1:8902 but with no success, maybe that's the reason the plugin doesn't help.
I've previously used Serviio to stream some movies and it worked just fine.
Thanks for the help and the plugin. :)
Cheers
Here's a ffmpeg -i log
C:\Program Files\Serviio\lib>ffmpeg -i "http://127.0.0.1:8902/"
[h264 @ 038FFF40] non-existing PPS referenced
[h264 @ 038FFF40] non-existing PPS 0 referenced
[h264 @ 038FFF40] decode_slice_header error
[h264 @ 038FFF40] no frame!
[mpegts @ 01BEEB20] max_analyze_duration 5000000 reached at 5015467 microseconds
Input #0, mpegts, from 'http://127.0.0.1:8902/':
  Duration: N/A, start: 36327.101167, bitrate: 96 kb/s
  Program 1
    Stream #0:0[0x44](rus): Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo
, s16p, 96 kb/s
vlad2005
Post Sat Jan 17, 2015 9:49 am
Hi!
I'm interested about sopcast plugin, mostly by facility to restart playback automatically when stream is dead.
The idea is to make somehow that when sopcast streaming is changed, to automatically reload by TV.
Here this plugin seem to be perfect for that, but unfortunatelly, not work, at least in my expectation.
I have installed plugin, everything play fine, but when kill current instance of sp-sc-auth and start new one (same ports) my tv (sony 40w605B) show "Playback not available".
When press "Return" on my remote, i see that is selected second item in sopcast folder. If press on it, playback start with new stream.
But i like if is possibil that stream restart without intervetion using remote. Is this possibil?
Maybe is in upnp protocol something to force TV to reload stream?
Thanks for your work!!!
Return to Available plugins
