A few questions...brand new newb here
HellBoundSinner
Post Wed Feb 09, 2011 6:33 am
Hi all,
Just stumbled upon Serviio by accident and decided to give it a try. I added my folders and it recognized my PS3 with no problems. I am able to play everything so far except FLV files. Also it downloaded the cover art and such for movies...but some of the them are the incorrect ones for that movie. How do I go about changing those individual ones? Any help would be greatly appreciated.
Post Wed Feb 09, 2011 9:42 am
Re: A few questions...brand new newb here
There is no transcoding config for fvl in the PS3 profile yet, so you can be the first to help with this ;-) Post ffmpeg -i of the flv file (viewtopic.php?f=5&t=1123).
Regarding inline metadata, you should name your files as described here: http://www.serviio.org/index.php?option ... icle&id=12
To update the metadata, the easiest is to rename the file (or its parent folder) and wait for the change to be picked up by Serviio or click Force refresh.
HellBoundSinner
Post Wed Feb 09, 2011 7:53 pm
Really loving this media server. I changed the names of the movies with the year added and it worked perfectly getting the new cover art. I am noticing too it doesn't want to transcode mov files either. I am going to try the ffmpeg of the flv files to help out now. Thanks again for this cool program.
HellBoundSinner
Post Wed Feb 09, 2011 8:01 pm
FLV information
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "D:\Multimedia\Funny Clips\Flas
h Videos\asteroid hitting earth.flv"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[flv @ 010fbca0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 25.00 (25/1)
Input #0, flv, from 'D:\Multimedia\Funny Clips\Flash Videos\asteroid hitting ear
th.flv':
duration : 287
lasttimestamp : 287
datasize : 17672018
metadatacreator : FlixEngineLinux_8.0.11.0 (www.on2.com)
canSeekToEnd : 1
videocodecid : 4
width : 480
height : 352
videodatarate : 419
framerate : 25
videosize : 15372616
audiocodecid : 2
audiodatarate : 63
audiosize : 2299402
Duration: 00:04:47.41, start: 0.000000, bitrate: 492 kb/s
Stream #0.0: Video: vp6f, yuv420p, 480x352, 428 kb/s, 25 tbr, 1k tbn, 1k tbc
Stream #0.1: Audio: mp3, 44100 Hz, 2 channels, s16, 64 kb/s
Post Wed Feb 09, 2011 8:48 pm
Try this updated PS3 profile:
<Profile id="4" name="Playstation 3" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
            remux MKV with any video to MPEG2TS and possibly change audio to ac3, also AVI anfd FLV with H264
         <!-- all other unplayable files just transcode to mpeg2 -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="flv" />
HellBoundSinner
Post Sun Feb 13, 2011 9:20 pm
Zip,
Sorry to be dumb about this...how do I add this profile to the Playstation 3 profile?
Post Sun Feb 13, 2011 10:44 pm
http://www.serviio.org/index.php?option ... icle&id=16
Just replace the ps3 profile in that file with the text provided above.
HellBoundSinner
Post Sat Feb 19, 2011 12:10 am
Zip,
Applied the profile...now when i go into my folder that has flash movies...it will give a thumbnail now...so that's a good sign...however on that video I posted the information about, it plays the video and not the audio.
Post Sat Feb 19, 2011 12:53 am
try replacing this
with this
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="384">
in the profile above
HellBoundSinner
Post Mon Mar 07, 2011 3:15 am
Applied the profile and now that file plays...I tried some of the others...they will play but the sound is out of sync with the video. It's getting very close :D
Post Mon Mar 07, 2011 12:27 pm
And with:
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="192">
Users browsing this forum: Google [Bot] and 50 guests
