Sony Bravia 2013 DTS to AC3 5.1
reiman
Post Sun May 18, 2014 9:31 pm
I´ve got a Sony W905A 55" TV (2013) . I want DTS sound to be transcoded to DD (AC3) 5.1 ... ( Got a sonos playbar connected via optical out)
If i try the Sony Bravia 2012 profile DTS is transcoded to DD 5.1 ... but the aspect ratio is off.
If i try the Sony Bravia 2013 profile DTS is transcoded to PCM 2.0. Aspect ratio is correct.
Why is that? And.... How do I get it working the way i want it? I´m a noob at these things so I would a dumbed down explanation. THX!
Post Mon May 19, 2014 7:36 am
Re: Sony Bravia 2013 DTS to AC3 5.1
What is the original file format ?
What is your region, uk, us, etc ?
mkv/h264/dts
- will be transcoded in mpegts/mpeg2video/ac3 with Sony Bravia 2012 profile (but DAR option should probably removed for your device)
- will be delivered in native format with Sony Bravia 2013 profile ( Sony Optical Output delivered in downstream PCM 2.0...I don't know why, check sony menu options for optical option, keep original format...)
PS: I will probably moved your post to sony section...
reiman
Post Mon May 19, 2014 10:47 am
Illico wrote:What is the original file format ?
mkv/h264/dts
Playing MKV, have tried several different MKV files with the same result.
Region: EU (Sweden)
I have checked my optical stting on the tv, it is set for "auto", instead of PCM. Plex for exampel transcodes my DTS tracks to DD 5.1 ( But messes up AR), so does the 2012 Bravia profile with the same TV settings.
But the 2013 gets the correct AR, but fails with the DTS to DD 5.1 ... It seems to me that it could be fixed within the bravia 2013 profile, cuz it works with the 2012. But what do I know!
Thank you so much for taking the time and answering!
Post Wed Jun 04, 2014 2:04 pm
Could you try to edit the ../serviio/config/profiles.xml file (make a backup before) ?
Remove all DAR="16:9" option on sony2013 profile section, save, restart serviio service or reboot PC.
reiman
Post Wed Jun 04, 2014 9:34 pm
Illico wrote:Could you try to edit the ../serviio/config/profiles.xml file (make a backup before) ?
Got an error message after reboot with the "DAR=16:9" altered profiles.xml file. It said:" Cannot connect to serviio server. It doesnt seem to be running. Exiting..."
Put back the original profiles.xml and rebooted, serviio was working again.
Post Thu Jun 05, 2014 6:49 am
Did you replace the 2013 profile like this ?
    <Profile id="sony2013" name="Sony Bravia TV (2013)" extendsProfileId="1">
       <!-- this is WIP, should be included in the inheritance tree if possible -->
      <!-- 2013 models
             Codec list supported : http://pdf.crse.com/manuals/13MW802111/FR/codeclist.html#5
             - Still images: JPEG (*.jpg / *.jpe / *.jpeg), MPO (*.mpo), RAW (*.arw)
             - Music: LPCM, MP1L1 / MP1L2 / MP1L3 / MP2L1 / MP2L2 / MP2L3 / MP2.5L3 (*.mp3), AAC-LC / HE-AAC v1/v2 (*.mp4 / *.m4a / *.3gp / *.3g2), WMA9 (*.wma)
             - Video: MPEG1 / MPEG2PS / AVCHD , MP4, Xvid, Motion JPEG, VC1, MKV, 3gpp, MOV, WebM
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA (KDL-\d{2}W[689]\d{2}A.*)|(KD-\d{2}X9\d{3}A.*)</FriendlyName>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         <!-- act as WMP so that the TV doesn't show root categories -->
         <ModelName>Windows Media Player Sharing</ModelName>
         <ModelNumber>3.0</ModelNumber>
         <Manufacturer>Microsoft Corporation</Manufacturer>
      </DeviceDescription>
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
      <MediaFormatProfiles>
         <!-- Rename native WMA formats to those supported by the tv -->
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMABASE">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="WMAFULL">WMA_FULL</MediaFormatProfile>
         <!-- Rename 3gp profiles that can be played as AVC -->
         <MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
         <!-- Rename native avi formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
         <!-- Rename native mpeg2ts with h264+ac3/aac formats to those supported by the tv (aac support is not advertised by the renderer but it works) -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3,AVC_TS_HD_50_AC3,AVC_TS_HD_60_AC3,AVC_TS_HD_EU">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_24_AC3_T,AVC_TS_HD_50_AC3_T,AVC_TS_HD_60_AC3_T,AVC_TS_HD_EU_T">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <!-- Rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_24_AC3_ISO,AVC_TS_HD_50_AC3_ISO,AVC_TS_HD_60_AC3_ISO,AVC_TS_HD_EU_ISO">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
      <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.2 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <!-- expected profile MPEG_TS_SD_EU/MPEG_TS_SD_NA/MPEG_TS_SD_KO -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="high_444" />
            <Matches container="*" vCodec="h264" profile="high_422" />
            <Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
         <!-- Remux containers with h264 video + AC3 audio to MPEG-TS stream without transcoding -->
         <!-- Remux matroska/mpeg2video + AC3 audio to MPEG-TS stream without transcoding -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="avi" vCodec="h264" aCodec="ac3" />
            <Matches container="flv" vCodec="h264" aCodec="ac3" />
            <Matches container="wtv" vCodec="h264" aCodec="ac3" />
            <Matches container="matroska" vCodec="mpeg2video" aCodec="ac3" />
         <!-- Remux all other h264 video to MPEG-TS stream with ac3 audio transcoding -->
         <!-- Remux all other matroska/mpeg2video to MPEG-TS stream with ac3 audio transcoding -->
         <Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
            <Matches container="*" vCodec="h264" aCodec="truehd" />
            <Matches container="*" vCodec="h264" aCodec="flac" />
            <Matches container="wtv" vCodec="h264" />
         <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio -->
            <Matches container="mpegts" vCodec="vc1" />
            <Matches container="flv" />
            <!-- example: flv/vp6/mp3 -->
            <Matches container="wtv" />
            <Matches container="ogg" />
            <Matches container="rm" />
            <!--Matches container="3gp" vCodec="mpeg4" /-->
            <!--Matches container="3gp" vCodec="h263" /-->
            <!-- digital camera video formats -->
            <Matches container="asf" vCodec="vc1" aCodec="wmapro" />
            <Matches container="mp4" vCodec="dvvideo" />
         <Audio targetContainer="lpcm" forceInheritance="true">
            <Matches container="rtp" />
            <Matches container="rtsp" />
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <HardSubsTranscoding>
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" />
      </HardSubsTranscoding>
reiman
Post Thu Jun 05, 2014 6:25 pm
I just deleted "DAR=16:9" from the profile.
If I erase my config and copy/paste the text below, same result as before. Serviio doesnt start. Am I doing it right? THX for the input...
Illico wrote:Did you replace the 2013 profile like this ?
      <!-- 2013 models
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <DeviceDescription>
         </Audio>
Post Fri Jun 06, 2014 9:50 am
reiman wrote:I just deleted "DAR=16:9" from the profile.
Could you attach your profiles.xml file ?
reiman
Post Fri Jun 06, 2014 1:28 pm
This is the original profiles.xml ... Did you want me to post the one with "DAR=16:9" deleted?
profiles.xml
(139.35 KiB) Downloaded 909 times
Post Fri Jun 06, 2014 3:08 pm
Could you try with this one ?
profiles.xml
(139.31 KiB) Downloaded 1069 times
reboot PC or restart serviio service
reiman
Post Fri Jun 06, 2014 10:10 pm
Illico wrote:Could you try with this one ?
profiles.xml
It doesn´t convert DTS to DD 5.1... Seems the same as with the original profiles.xml
Is there some setting in serviio I should try?
snappyfish
Post Sat Dec 06, 2014 1:51 pm
Hi, I love serviio so far. But I only get DTS surround sound from sony bravia 2011 us profile but aspect ratios are wrong. Using Bravia 2013 profile aspect ratios are correct but dts does but only stero sound?
snappyfish
Post Sun Jan 25, 2015 8:43 pm
No one?
Post Mon Jan 26, 2015 5:25 pm
Could you provide information about your file streamed ? is it mkv, ts...
see signature link
Users browsing this forum: Google [Bot] and 53 guests
