Serviio console Library tab all messed-up
Gregorius
Post Wed Jun 04, 2014 5:07 pm
Hi! Recently I am experiencing problems with the Library tab of my Serviio console. There have been no changes whatsoever to the configuration of Serviio. From one day to the other the Library tab became empty. No tab rendering is done when switching to it. Once there From/Window elements get rendered once hovered and need to be changed due to hover effects. Unfortunately not all elements require re-rendering on hover.
See attached screenshots for the behavior of the window with the cursor having dragged all over the window.
Pretty nice effect but quite useless. :)
Any one else have had this problem before or recently?
Ah! We are getting there...!
Ooops, something happened
Nothing basically
Post Thu Jun 05, 2014 12:54 pm
Re: Serviio console Library tab all messed-up
Not seen it like this before but similar problems have been fixed by re-installing Java. Use the Java removal tool to completely uninstall Java and then re-install the latest version. See if that fixes the issue.
Gregorius
Post Fri Jun 06, 2014 5:31 pm
Thanks DenyAll!
It must have been the Java indeed. Actually, no re-install was necessary. I usually put my computer to Hybernate. I just remembered when you mentioned Java that if I recall correctly, I installed a Java update a couple of days ago, because I was too much bothered by the Java update pop-ups here and there. And of course once finished I did not restart the computer but put it to hibernate. Restarting actually solved the issue.
Thanks again!
KR,
Gergely
