Problem with FFMPEG or Java
Zikofski
Post Mon Aug 12, 2013 9:22 pm
im new to this, i managed to get serviio working minus a few profile issues but il try and get that sorted later.
something happened that i needed to reinstall everything again time consuming but since that i have an error in my log which is preventing serviio from finding and adding files
here is part of the log in question
2013-08-12 22:08:03,801 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /mnt/raid/Storage/Movies/DVD/The Fog (2005).mkv
2013-08-12 22:08:03,801 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /mnt/raid/Storage/Movies/DVD/The Fog (2005).mkv
2013-08-12 22:08:03,802 DEBUG [ProcessExecutor] Starting ffmpeg -i /mnt/raid/Storage/Movies/DVD/The Fog (2005).mkv
2013-08-12 22:08:03,811 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "ffmpeg": java.io.IOException: error=2, No such file or directory
java.io.IOException: Cannot run program "ffmpeg": java.io.IOException: error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:488)
at org.serviio.external.ProcessExecutor.run(ProcessExecutor.java:135)
Caused by: java.io.IOException: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
at java.lang.ProcessImpl.start(ProcessImpl.java:81)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:470)
... 1 more
2013-08-12 22:08:03,812 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2013-08-12 22:08:03,812 WARN [LibraryManager] Skipping processing metadata for an unsupported file (The Fog (2005).mkv). Message: Unknown video file type.
now from reading it i am unsure what is causing the error but i think its one of two things java or FFMPEG
this is the process i used to build ffmpeg on my system
cd ~/src
wget http://download.serviio.org/opensource/ffmpeg-N-54096-ge41bf19.tar.gz
tar xzvf ffmpeg-N-54096-ge41bf19.tar.gz
cd ffmpeg
./configure --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb \
    --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 \
    --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp \
    --enable-libxvid --enable-libass
make
sudo checkinstall --pkgname=ffmpeg --pkgversion="99:$(date +%Y%m%d%H%M)-git" --backup=no --deldoc=yes --fstrans=no --default
forgot to mention i am using ubuntu 12.04 server, and i did use this walkthrough here to help me (http://wiki.serviio.org/doku.php?id=build_ffmpeg_linux), altho i changed to the source linked from the serviio main website
Post Mon Aug 12, 2013 9:29 pm
Re: Problem with FFMPEG or Java
where did it install the ffmpeg binary? Is it on path? If not, you can point to it with ffmpeg.location system variable (see FAQ for how to do that)
Zikofski
Post Mon Aug 12, 2013 9:33 pm
no idea tbh i am no good with linux myself i presume it is left in ~/src/ffmpeg
il scan through hte FAQ and have a look maybe that is the issue here,
another question regarding the LOG, how oftern dose it clear its content's and if i delete its contents will that cause issues?
Post Mon Aug 12, 2013 9:47 pm
you can delete the log, no problem
Zikofski
Post Tue Aug 13, 2013 9:26 am
okay so i found out where it is installed by using the command
which ffmpeg
usr/local/bin/ffmpeg
okay so i added this to serviio.sh
-ffmpeg.location=$usr/local/bin/ffmpeg
in the line JAVA_OPTS
but now my serviio will not run and when i try to start i get this
serviio
Unrecognized option: -ffmpeg.location=/local/bin/ffmpeg
Could not create the Java virtual machine.
not sure if my syntax is correct?
EDIT: i have removed the $ from the string and now i get
Unrecognized option: -ffmpeg.location=usr/local/bin/ffmpeg
Post Tue Aug 13, 2013 9:34 am
You have to add
-Dffmpeg.location=/usr/....
to the list of other -D parameters
asharp
Post Mon Jun 09, 2014 2:12 am
It appears that this issue has "re-appeared". OS: FreeBSD v10 and Serviio Pro (1.4.1.2). Unfortunately, this may have been happening since I moved to v10. The system was completely rebuilt and I may have missed that this was happening.
Log:
2014-06-08 21:56:27,981 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/usr/local/bin/ffmpeg": error=2, No such file or directory
java.io.IOException: Cannot run program "/usr/local/bin/ffmpeg": error=2, No such file or directory
And yet, the file is there:
# which ffmpeg
# ffmpeg
ffmpeg version 2.1.1 Copyright (c) 2000-2013 the FFmpeg developers
built on Apr 22 2014 23:56:04 with FreeBSD clang version 3.3 (tags/RELEASE_33/final 183502) 20130610
configuration: --enable-libaacplus --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-libass --disable-libcdio --enable-libcelt --enable-libfaac --enable-libfdk-aac --enable-ffserver --enable-fontconfig --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-iconv --disable-indev=jack --enable-libmp3lame --enable-libbluray --disable-libv4l2 --disable-indev=v4l2 --disable-outdev=v4l2 --enable-libmodplug --enable-openal --enable-libopencv --enable-libopenjpeg --enable-libopus --disable-libpulse --disable-indev=pulse --disable-outdev=pulse --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --disable-vaapi --disable-vdpau --enable-libvorbis --disable-libvo-aacenc --disable-libvo-amrwbenc --enable-libvpx --enable-libx264 --enable-libxvid --prefix=/usr/local --mandir=/usr/local/man --datadir=/usr/local/share/ffmpeg --enable-shared --enable-gpl --enable-postproc --enable-avfilter --enable-avresample --enable-pthreads --enable-memalign-hack --disable-libstagefright-h264 --disable-libutvideo --disable-libsoxr --cc=cc --extra-cflags='-msse -I/usr/local/include/vorbis -I/usr/local/include' --extra-ldflags='-L/usr/local/lib ' --extra-libs=-pthread --disable-debug --enable-nonfree --enable-version3
libavutil 52. 48.101 / 52. 48.101
libavcodec 55. 39.101 / 55. 39.101
libavformat 55. 19.104 / 55. 19.104
libavdevice 55. 5.100 / 55. 5.100
libavfilter 3. 90.100 / 3. 90.100
libavresample 1. 1. 0 / 1. 1. 0
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
Use -h to get full help or, even better, run 'man ffmpeg'
Tried the "-Dffmpeg.location" and didn't help. Any recommendations on how to resolve this? Experiencing the **same** issue with dcraw. Both dcraw and ffmpeg were installed prior to the installation of Serviio. Is there a means to increase logging (to a greater debug level)? Certainly willing to try to track down the specifics, but not being a java developer - not sure where to begin looking without some minor guidance.
FWIW - I do have some other applications (same machine) that use/rely on ffmpeg and those operate without issue.
Post Mon Jun 09, 2014 7:50 pm
perhaps the user running serviio doesn't have access to the executable?
asharp
Post Mon Jun 09, 2014 10:32 pm
As the user, ffmpeg can be executed. Shouldn't be a permissions issue with ffmpeg unless there is some change in how it operates from previous versions. Looking again at the log file, it appears that perhaps: Is it possible that if a file is an "unknown" format or type to ffmpeg that serviio will still show this error? ie: ffmpeg is there, get's executed, but serviio thinks that ffmpeg didn't actually run because there is no output from ffmpeg? Suggesting that there is a difference between "I can't find and/or run ffmpeg" vs. "I executed it, but I received no data from it". At present, the log "implies" that it couldn't find/execute ffmpeg, even if it did.
Thoughts?
Post Tue Jun 10, 2014 4:31 pm
The error means the Java process cannot find the file or is not readable.
I assume if you execute /usr/local/bin/ffmpeg it works in the terminal?
asharp
Post Wed Jun 11, 2014 12:51 am
Correct. Results when executed as the same user (via "su - dlna") that serviio runs as (the path to ffmpeg is also correct - as stated in the serviio log file):
dlna$ ffmpeg
A point to my previous statement. Here is a snippet from the log file (filename obscured):
2014-06-10 20:00:20,236 WARN [ProcessExecutor] Cannot retrieve results, output reader is null
2014-06-10 20:00:20,236 WARN [LibraryManager] Skipping processing metadata for an unsupported file (<PATH_TO_FILE/FILENAME>). Message: Unknown video file type.
2014-06-10 20:00:20,236 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "/usr/local/bin/ffmpeg": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1041)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:184)
at java.lang.ProcessImpl.start(ProcessImpl.java:130)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1022)
... 1 more
Hopefully this helps.
Post Wed Jun 11, 2014 11:31 pm
Try to play with the access rights (eg give the executable access to everyone).
asharp
Post Fri Jun 13, 2014 6:30 pm
Permissions are already (and have been) the stock permissions of 0755. All users can execute. There should not be any permissions problems.
Users browsing this forum: No registered users and 401 guests
