Xbox One and Mediabrowser
• Page 1 of 1
In the past I used the build-in DLNA Client to stream the media files from my NAS (Serviio installed) to my PS3. Unfortunately the Xbox One has no full DLNA Client. So as a workaround I tried to use the mediabrowser. But there are still some issues. I am able to navigate through the categories (Audio, Video, Pictures), but there are no buttons visible in the black window (Play, stop button). I cannot Play the media files except mp3 - i double click in the window and then I locate the Position where the Play button exists. Is there any trick how to Play the media files through mediabrowser? Meanwhile i Use skifta for my android instead of ServiioGo cause this app is able to stream the files from my nas to a different device like the TV or the Xbox. Is this Feature also coming to ServiioGo?
Re: Xbox One and Mediabrowser
Maybe worth trying to force Serviio to use the playstation 4 profile (or an Ipad one) as it may not support flash but might support HTTP live streams
This seems to suggest something along those lines
http://support.xbox.com/en-GB/xbox-360/ ... -dont-work
https://www.3ivx.com/xbox/
If its the case then Its just a case of making a suitable profile
Xbox One Media Player coming soon that supports DNLA!!!
The big surprise it supports just about anything from mkv, divx, xvid and so much more!!
Preview found here - https://www.youtube.com/watch?v=qe28yty02SI
Xmantium wrote:Xbox One Media Player coming soon that supports DNLA!!!
Well thats good news!
If anyone does have a Xbox one, its probably worth trying to force the web browser to use the playstation 4 profile to see if it will support MB playback as a profile for it could be developed
• Page 1 of 1
