Process ffmpeg has a return code of 1! - Ubuntu
_Crash_
Post Sun Jun 22, 2014 8:39 am
Every time I try and play any video, it just sits there with the loading icon.I checked the log and It's put me at a dead end since all I got was this;
2014-06-22 11:23:21,250 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-960-flv_player-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-06-22 11:23:21,654 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
ffmpeg version 0.8.12-4:0.8.12-0ubuntu0.12.04.1, Copyright (c) 2000-2014 the Libav developers
built on Jun 10 2014 15:31:10 with gcc 4.6.3
Expected number for threads but found: auto
The Web UI doesn't throw an error either when i'm trying to play it. I had a feeling it might be something to do with the presets but I don't want to modify anything in-case it makes it worse.
I followed this tutorial.
Any ideas?
Post Tue Jun 24, 2014 5:07 pm
Re: Process ffmpeg has a return code of 1! - Ubuntu
You're using an old version of ffmpeg, you'll have to build your own. There are some tutorials on the wiki or ffmpeg website.
