Es5500 not dscoverable after Firmware update
B _green
Post Sat Jun 21, 2014 10:00 am
Hi I updated the firmware on my TV last night to version 2000.2 http://www.samsung.com/uk/support/model/UE40ES5500KXXU the serviio option now no longer appears in the sources list. Serviio console can discover the TV and there is a green dot in the status with the correct IP address. It was working well before the firmware update. I have tried both the basic DLNA and samsung E/F profiles without luck. Is there anything else I can try?
B _green
Post Tue Jun 24, 2014 6:17 pm
Re: Es5500 not dscoverable after Firmware update
Anyone? Or do I have to delete all my files and get a DVD player? :roll:
Post Wed Jun 25, 2014 10:04 am
Have you removed the TV from the renderer list in Serviio? Try it and see if it's rediscovered.
Other than that, see if a detailed log sheds any light on it.
