Thu Sep 20, 2012 9:06 pm by stopmakingsense
Hi there,
My first post on the forum... I hope I'm posting in the right place!
I've installed Serviio 1.0.1 on one of my networked PCs running XP, to stream my media library around the house...
I have a Samsung B series in my bedroom which seems to work fine over a wired connection... I also have an XBox360 in another room which also appears to work fine over a wireless connection... The problem I have is in the lounge with my Samsung ES8000... The TV sees the Serviio server on start up, but disconnects no matter what I'm doing within the first five minutes... I've seen the posts suggesting it's a problem with FFMPEG and I have replaced the exe with the latest version, but it hasn't fixed the problem... As I say, I can connect to the server and simply navigate the directory structure, the TV still disconnects after 3-5 minutes, as if it is a time-out of some description... I usually run the TV connected to a wireless access point, but I've also tried it directly wired to the main router in my office, with the same result... For information, Netflix works fine without any streaming issues, so I don't suspect the network...
Serviio log file attached in DEBUG mode whilst navigating the directory structure on the TV during this latest disconnect... I hope it sheds some light on the problem...
Regards,
- Attachments
- (281.82 KiB) Downloaded 751 times
