SAMSUNG H SERIES 2014
I have problems with big files by using F Series profile.
mikeyking wrote:I'm having issues with getting the 'Online' bits to work (SopCast & AceStream). I think it's potentially down to me using the E/F profile on a H 2014 Samsung? Anyone got a newer profile for the H series?
<Profile id="sam_h" name="Samsung TV / player (h-series)" extendsProfileId="1">
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
<Detection>
<UPnPSearch>
<FriendlyName>(^\[TV\][A-Z]{2}\d{2}(E|F)[A-Z]?\d{3,4}.*)|^\[TV\] Samsung</FriendlyName>
<ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
</UPnPSearch>
<HttpHeaders>
<!-- for BD players -->
<User-Agent>(.*SEC_HHP_BD-[EF].*)|(.*SEC_HHP_\[(HT|BD)\][EF].*)</User-Agent>
</HttpHeaders>
</Detection>
<DeviceDescription>
<ExtraElements>
<sec:ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:ProductCap>
<sec:X_ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:X_ProductCap>
</ExtraElements>
</DeviceDescription>
<MediaFormatProfiles>
<MediaFormatProfile mime-type="video/x-mkv">MATROSKA</MediaFormatProfile>
<MediaFormatProfile mime-type="video/x-msvideo" name="">AVI</MediaFormatProfile>
<MediaFormatProfile mime-type="audio/x-flac">FLAC</MediaFormatProfile>
</MediaFormatProfiles>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
<!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192" forceInheritance="true">
<Matches container="*" vCodec="h264" profile="high_10"/>
<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2"/>
<Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2"/>
<Matches container="mp4" vCodec="mpeg4" aCodec="lpcm"/>
<Matches container="mp4" vCodec="dvvideo"/>
<Matches container="mp4" vCodec="mjpeg"/>
<!-- transcode H264 MP4 files with LPCM audio -->
<Video targetContainer="mpegts" targetACodec="ac3" forceInheritance="true">
<!-- Matches container="mpegts" aCodec="mp2" /-->
<Matches container="mp4" aCodec="lpcm"/>
<!-- <Matches container="flv" vCodec="h264" /> -->
<Matches container="matroska" vCodec="h264" aCodec="flac"/>
<Matches container="matroska" vCodec="h264" aCodec="vorbis"/>
<Matches container="matroska" vCodec="h264" aCodec="truehd"/>
<Matches container="mpegts" vCodec="h264" aCodec="truehd"/>
<Matches container="ogg" vCodec="mpeg4"/>
<Matches container="3gp" vCodec="h264" aCodec="amrnb"/>
<Matches container="wtv" vCodec="h264"/>
<Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" forceInheritance="true">
<Matches container="matroska" vCodec="mpeg2video"/>
<Matches container="matroska" vCodec="vp8"/>
<Matches container="matroska" vCodec="vc1" aCodec="truehd"/>
<Matches container="avi" vCodec="h264"/>
<Matches container="avi" vCodec="mjpeg"/>
<Matches container="avi" vCodec="dvvideo"/>
<Matches container="flv" vCodec="flv"/>
<!-- some models support playing flv natively, in that case remove this line -->
<Matches container="flv" vCodec="h263"/>
<Matches container="flv" vCodec="vp6"/>
<Matches container="3gp" vCodec="h263"/>
<Matches container="3gp" vCodec="mpeg4"/>
<!-- some cameras produce mp4 codec that won't play -->
<Matches container="ogg"/>
<Matches container="rm"/>
<!-- some models might support RealVideo natively, in that case remove this line -->
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" forceInheritance="true">
<Matches container="asf" vCodec="mpeg2video"/>
<Matches container="asf" vCodec="mpeg1video"/>
<Video targetContainer="mpegts" forceInheritance="true">
<Matches container="wtv"/>
<!-- transcode wmv2-wmav2, not: wmv3-wmapro it works ok on E series-->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true">
<Matches container="asf" vCodec="wmv2"/>
<Audio targetContainer="lpcm" forceInheritance="true">
<Matches container="mp4"/>
<Matches container="adts"/>
<Matches container="mp2"/>
<Matches container="wavpack"/>
<Matches container="mpc"/>
<Matches container="ape"/>
<Matches container="asf"/>
</Audio>
<OnlineTranscoding>
<Matches container="applehttp" vCodec="h264"/>
<!-- mms -->
<Matches container="flv"/>
<!-- transcoding all flv streams, even h264, to avoild premature disconnects, to avoid this, use Samsung C/D profile -->
</OnlineTranscoding>
<Subtitles>
<SoftSubs mime-type="smi/caption"/>
</Subtitles>
Scot1970 wrote:Hi there,
I am experiencing similar problems with the Samsung UE48H6400. With 'big' files, ie films, I cannot fast forward because the Smart hub then tells me either "this video data is not supported" or "please check your network connection" and then I have to come out out of the multimedia and go back in and start from scratch. The film files tend to be mp4s or mkvs, and they worked perfectly on my previous TV, which was a Samung UE40ES6300.
My wireless router is a brand new Virgin Media "Superhub" 5GHz and is less than two metres away from the TV. When I check network status I get a full 5-bar signal report. HD streaming is smooth and trouble-free so I am concluding that the trouble lies with the communication between Serviio and the Smart hub software.
I have added the H series profile that was very kindly provided on this thread (thank you). However, the problem persists. Also, when playing music files, especially playlists (which play fine for me as m3u files), the same problem happens when I try to fast forward or jump to the next track.
Please can you advise. These problems did not exist with my previous Samsung TV.
Thank you
