Buffering with Samsung Evolution Kit Sek-2000/XC
Dario
Post Sun Jun 29, 2014 6:06 pm
Since I upgraded my E8000 Serie Samsung TV set with the proper Evolution Kit (Sek-2000/XC) DLNA streaming doesn't work so good anymore. I can see a little buffering randomly and after that 1 second of the movie is missing. I think that's a profile issue, because I have no issue at all by using a LG TV. Do you think there will be a dedicated profile setting for this kind of Samsung upgrade kit?
That's the link
http://www.samsung.com/us/video/tvs-acc ... EK-2000/ZA
Post Sun Jun 29, 2014 7:47 pm
Re: Buffering with Samsung Evolution Kit Sek-2000/XC
Probably not a profile issue, as Samsung profile hardly transcodes anything, it's probably a network latency issue.
Dario
Post Thu Jul 03, 2014 8:49 am
zip wrote:Probably not a profile issue, as Samsung profile hardly transcodes anything, it's probably a network latency issue.
If it can help, I noticed that the issue doesn't occur streaming video files less then 720p resolution
Post Thu Jul 03, 2014 3:51 pm
If you're on a wifi, it'll be that. Network quality changed.
Return to User experiences
