Serviio V1.4 on unRaid
mayhem2408
Post Tue Aug 21, 2012 12:12 am
This is a plugin to install Serviio V1.4 on unRaid servers.
Installation:
create a directory called "plugins" at the root of your unraid USB key and copy the .plg file into it. There are two plugins to choose from. One called cache and one called flash. The Cache version of the plugin will install serviio onto your cache drive. If you do not have a cache drive, use the flash version of the plugin to install serviio onto your USB boot flash drive.
Run:
The plugin script will automatically run when the unRAID server starts up.
However, it you want to start the plugin without rebooting, either go to the console or telnet into the server
as the prompt, type
installplg /boot/plugins/serviio-1.4-1jr-flash.plg
or
installplg /boot/plugins/serviio-1.4-1jr-cache.plg
After running the install, you will need to reboot your unraid server for the database creation to start.
As of plugin version 1.0.1-2, it is no longer nessessary to remove the old Version 1.0 folders as the new script will be able to update the program files and leave your original database intact. If you have a version prior to V1.0, (Beta versions included), the new version will install and new folder leaving your old version intact, but dues to database changes, your old data will not be compatible with the new version and will have to be set up as new.
This installation also includes all the online source plugins as at 21/08/2013.
History:
2013-08-21 1.4-1jr - Updated to Serviio V1.4, Latests Plugins.
]2013-08-21 1.3.1-1jr - Updated to Serviio V1.3.1, Latests Plugins.
2013-03-29 1.2.1-1jr - Updated to Serviio V1.2.1, Latests Plugins.
2013-03-02 1.2-1jr - Updated to Serviio V1.2, Plugins for V1.2.
2013-02-12 1.1-10jr - Complete rewrite of the ffmpeg package. ffmpeg and librarys are now in a slackware package for easy installation or portability.
2013-02-06 1.1-9jr - Big rewrite of the rc.serviio start and stop routines and complete rewrite on disks_mounted and unmounting_disks. Should fix issues causing the script to fail and for some people preventing the unRAID server from stopping the array cleanly.
2013-02-05 1.1-8jr - Modified ffmpeg installer so it will run smoother with the modified subsonic plugin
2013-02-04 1.1-8.0jr - Modified some of the code that handled version numbering. Does not affect the functionality of the plugin. Just makes it easier to maintain.
2013-02-04 1.1-7jr - Relocated the unpack script to rc.serviio which is only executed once the array comes on line. Should solve the ffmpeg issue once and for all.
2013-02-04 1.1-6jr - temporary work around for ffsetup.sh script issue on cache drives.
2013-01-29 1.1-5jr - Added a Done button to the Serviio settings page.
2013-01-27 1.1-4jr - Added file permissions correction and fix a bug in the unpack script.
2013-01-26 1.1-3jr - Added libdc1394 and libraw1394 packages at the request of piotrasd.
2013-01-23 1.1-2jr - Updated jre to 7u2. Serviio V1.1 seems stable on 7u2 with unRaid now.
2013-01-15 1.1-1jr - Updated to Serviio V1.1, Webui V1.0.1 and Plugins. as of 2013-01-14
2012-09-11 1.0.1-5jr - Corrected a minor bug in the unpack script.
2012-08-23 1.0.1-4jr - Updated version detection in script. Reduced code size and faster.
2012-08-21 1.0.1-3jr - Updated online sources plugins now with over 70 supported
2012-08-19 1.0.1-2jr - Updated unpack script so it can upgrade V1.0 servio to V1.0.1 without a clean install
2012-08-19 1.0.1-1jr - Updated to Serviio V1.0.1
2012-05-02 1.0-1jr - Reverted to jre 6u27. Included support for over 50 online sources. Updated to Serviio V1.0
2012-04-27 0.9-1jr - Updated jre to 7u2 (from 6u27)
2012-04-20 0.8-1jr - Moved plugins to /boot/plugins and packages to /boot/packages
2012-04-20 0.7-1jr - Included the download and installation of java jre-6u27-i586-1aj
2012-04-18 0.6-1jr - Added page, php and png files for unraid/serviio webui intergration
2012-04-17 0.5-1jr - Added WebUI accessable at http://tower:8123/serviio/console
2012-04-17 0.4-1jr - Created a dropbox account to access the ffmpeg files required by serviios transcoder
2012-04-17 0.3-1jr - Modified the disks_mounted event to only start attempt to start serviio if it is not running
2012-04-16 0.2-1jr - Modified to use unRAID V5.0 events instead of the unraid_addon_control.sh script
2012-04-15 0.1-1jr - first release
Please report any problems with the plugin here. If you have specific issues or feature requests with Serviio, please direct them here http://forum.serviio.org/
Files:
plugin file: http://dl.dropbox.com/u/73389880/serviio-files/serviio-1.4-1jr-cache.plg
plugin file: http://dl.dropbox.com/u/73389880/serviio-files/serviio-1.4-1jr-flash.plg
2013-04-24: For the users out the that also want to use the Subsonic Streamer, I have modified the original subsonic plugin so that is does not clobber the newer ffmpeg installed by my plugin and fixed an issue that was preventing subsonic from using the newer ffmpeg I installed when working from the USB boot drive.
plugin file: http://dl.dropbox.com/u/73389880/subsonic-files/subsonic-4.8-1.0.0jr.plg
Screenshots:
https://play.google.com/store/apps/details?id=com.serviidroid&hl=en
https://play.google.com/store/apps/details?id=com.serviigo
sam9s
Post Mon Aug 27, 2012 7:20 pm
Re: Serviio V1.0.1 on unRaid
Hi All
I am haveing a problem ....... Installed, up and running ..... beautifull interface ..... I can add audio files that I am able to view from my tab, but video files do not show ...... tried couple of things but in no vain ........
Also whats the password for Serviio Media Browser .. it says to set it at serviio consold, but I can not find any where in the console where I can set the password for web access ......
Kindly assist
Regards
Sammy
Stoned99
Post Sat Jan 12, 2013 1:12 am
Hey Mahem, by any chance, would you be able to update the package so it installs version 1.1.? I did some tests on my end but with no joy. Had to go back to 1.01.
dardrian
Post Fri May 24, 2013 5:29 pm
Re: Serviio V1.1 on unRaid
sorry for my english, i'm a french.
I have installed serviio 1.2.1 on unraid server with successfull ( serviio is running,Java version 1.7.0_02 is currently running.)
, but when i try to open the serviio console (http://serveurnas:8123/serviio/console), i get an error loading the page(failed connection).
chriscullen_uk
Post Thu Jul 03, 2014 7:13 pm
Re: Serviio V1.4 on unRaid
Hi having a problem installing the Serviio on Unraid - have 5.0.5 basic. Get the following errors:
Jul 3 19:54:32 Unraid logger: Installing system plugins
Jul 3 19:54:32 Unraid logger: installing plugin: serviio-1.4-1jr-flash
Jul 3 19:54:32 Unraid logger: file /boot/packages/jre-7u2-i586.txz: downloading from http://dl.dropbox.com/u/73389880/jre-fi ... 2-i586.txz ... bad download, deleting
Jul 3 19:54:32 Unraid logger: installing plugin: subsonic-4.8-1.0.0jr
Jul 3 19:54:32 Unraid logger: file /boot/packages/jre-7u2-i586.txz: downloading from http://unraid-subsonic-plugin.googlecod ... 2-i586.txz ... bad download, deleting
Jul 3 19:54:32 Unraid logger: Installing user plugins
Jul 3 19:54:32 Unraid logger: Starting go script
What is this bad download issue - I have uMenu working fine
