spudy12 wrote:Hi Will
Any news on the chromecast integration?
==== 4.1 ====
*Response caching now supports very large folders
*Various performance improvements to parsing responses and loading from cache
*Show a message rather than a 'Force Close' dialog whenever the app crashes (as was done prior to 4.0)
*Don't show an ActionBar subtitle when loading folders of unknown size
*Fixed some bugs on Android L preview
*Updated ListViewAnimations
*Updated build tools
will wrote:spudy12 wrote:Hi Will
Making progress, but nothing new to report. Having to do lots of other background changes to support it.
spudy12 wrote:Hi will. Can't remember if I imagined it or not but I thought I saw somewhere you had a version that you could side load on to a kindle? Did I imagine that or is there one that doesn't require google play.
Cheers
spudy12 wrote:How do we get a copy off the play store to transfer to the kindle or do we need to copy it from a rooted device?
will wrote:spudy12 wrote:How do we get a copy off the play store to transfer to the kindle or do we need to copy it from a rooted device?
You don't need a rooted device, either use adb to pull the apk from your phone, or download one of my many apps that will do it for you from Google Play, e.g. 'Apk Share & Backup'.
spudy12 wrote:One final question from me, how likely is it that offline viewin ticket 28 (https://bitbucket.org/willlunniss/servi ... ne-viewing) will be intergrating in to serviigo?
Any major hurdles stopping it?
EDIT: I'm also having real trouble with the music player running inside bluestacks. Everytime I select a song it crashes. Video is working okay using the internal player for medium and low qualities but not for original. (Think thats a bit rate issue)
This is all I can see in log files?
http://gyazo.com/d72a9d0ca293cdc0d2aebbcb4e4d61f3
will wrote:spudy12 wrote:One final question from me, how likely is it that offline viewin ticket 28 (https://bitbucket.org/willlunniss/servi ... ne-viewing) will be intergrating in to serviigo?
I've got a prototype working. The main hurdle is time, which I have very little of at the moment.
The release builds on Google Play contain very little logging, so I'm not surprised its blank.
I'll have to install it to work out what is wrong, the crash report doesn't really make sense, but then they have messed with parts of the platform.
spudy12 wrote:I understand, time is always hard to come by these days!
Good to know that it's on it's way though. Will it just download the original file, or will it download it at the quality for that device / chosen?
Just thought with offline downloading it could be an iplayer offline watch style setup whilst travelling.
Yes they have messed around with it a lot so I'm surprised any of it worked.
I have eventually found a way to remove all their crap, root it and make it run like a standard android tablet. (http://forum.xda-developers.com/showthr ... 44&page=24) -- use version 0.8.11 of the offline installer
Can you think of any reason why original quality playback would not work on either Internal / External player or standard and enhanced profiles?
VLC has the best luck out of the lot - plays a few frames then video freezes.
==== 4.2 Beta 1 ====
*Improved loading of very large folders
*Added a button to the notification to stop the Music Player (Android 4.0+) (#88)
*Workaround a crash in the Music Player when running under BlueStacks
*Various minor bug fixes
*Updated Google Play Services to 5.0
*Updated Android Support Library to revision 20
bengio wrote:Hi Will. Where and how can i have the 4.2 beta 1?
Inviato dal mio LT26i utilizzando Tapatalk
