Incorrect movie title?
falcon15500
Post Tue May 20, 2014 9:32 am
Hi all,
Looking for a little advice on where to start.
I have movie that is named in the same format as all my other movies, however it gets imported to the library as something else.
/mnt/movies/LEGO.Movie,The.(2014)-tt1490017/The.LEGO.Movie.avi
It gets picked up and imported as:
2014-05-20 19:27:55,099 INFO [LibraryAdditionsCheckerThread] Added file 'The.LEGO.Movie.avi' (title: Jack Ryan: Shadow Recruit) to Library
Any thoughts? Maybe it is a problem because of the uppercase nature of the title? I tried enabling debug logging, however it didn't really provide anything useful.
M.
Post Tue May 20, 2014 12:53 pm
Re: Incorrect movie title?
You guessed it - renaming the file name to The.Lego.Movie.avi fixed the issue on my system (note - no longer uppercase). The path stayed the same.
Not sure why though - perhaps zip may need to investigate what the underlying cause is and whether it is a bug.
falcon15500
Post Wed May 21, 2014 2:28 am
DenyAll wrote:You guessed it - renaming the file name to The.Lego.Movie.avi fixed the issue on my system (note - no longer uppercase). The path stayed the same.
Wow! Thanks again. Worked a treat. :)
M.
Darkfalz
Post Sun Jul 06, 2014 7:39 am
I had this identified as first X-Men: DOFP and then Captain America: The Winter Soldier.
Will try making it lowercase.
Sony KDL-55HX750 and BDV-N990W (Home Theatre)
Sony KDL-40D3100 and BDP-S390 (Loungeroom)
Users browsing this forum: Baidu [Spider], Google [Bot] and 43 guests
